Careers Thread
    Are you guys using Revit for steel? Or one of the more boutique options? Keep in mind cadworx structure only just came out as a stand alone program two years ago. It took them a solid 4 years for them to fix plant after the 2013 rewrite.
    We have a number of immensely talented engineers and other employees on staff. Some sit on boards, some phds. I particularly enjoy working with some of the old timers, a couple have been in the industry for more than 60 years. They just keep going because they enjoy what they do. It's amazing the wisdom they bring to the table. You are absolutely on point that someone has to stamp stuff at the end of the day.
    You guys are taking yourselves so serious.... This is r3v after all. Acting like a bunch of engineers here, all broody. LOL
    ...what hasnít been done to an m20 yet?
    m20 Oil Stencil
      No, Revit doesn't really work for this industry (a lot of our work is retrofits and totally custom stuff). I can't imagine trying to use an architect program to design a drill site or a wharf for example.. that sounds horrible!
      We're using Tekla, which is quite excellent and actually less expensive than many alternatives (including our old Bentley software that we paid hundreds of thousands worth of maintenance for and never got an update in like 8 years). The irony is Tekla interoperates better with AutoCAD than Revit does, lol. I think Autodesk secretly wishes AutoCAD would go away.
      I tested every single structural modeling program that exists, except SDS/2 (which is $$$$). Cadworx steel is simply the worst one by far. It's like MS Paint vs Photoshop. They also made it clear they were never going to be adding the things we require to stay competitive. Unlike east coast engineering firms, we design and detail all of our own connections because everything has to meet seismic codes. The only thing it has going for it is the dirt cheap cost, but you get what you pay for in this case.
        I have never used tekla but I've read up a little on it. Seems like a mainstay. But yes, cadworx structure (and equipment) they are scrambling to technologically catch up to cadworx plant's functionality. What release/version of cadworx structure (or was it just the old “steel” supplemental module to plant) did you test/evaluate? Part of my job I have to stay on top of it as well.
        Intergraph/hexagon is a juggernaut in the space, they even dwarf Autodesk, but the left hand doesnt know the right hand in typical big company fashion. they don't move as fast as they should, or they move too quickly too often in a development direction that does nothing for the masses and average user. Slowly and surely as cadworx cannibalizes hexagon's own market share from smart3d, they cannot help themselves but to slowly over-complicate cadworx plant until it basically turns into smartplant.
        Meanwhile Autodesk is begging for AutoCAD to die, but it never will. So they sit there giving away Plant3d for free with AutoCAD now, but it's about as complex as cadworx was in 2011, just with an automated route function. Cadworx components work in AutoCAD better than Plant3d components. All bets are off looking forward now that hexagon bought up Bricscad, unless Autodesk can start to port models to their FEA engines.
        My company sent me to Hexagon's conference to look at the Lieca scanners along with the Plant software, supposed to be wanting me to go to the Autodesk University 2019 conference in November as well, we will see. Faro seems to be sharing the bed with Autodesk, their hardware is much more reasonably priced, but you do get what you pay for, sometimes. Get your company to send you to Vegas in November for AU, I should be there.
        Software release versions and updates can make or break not just projects but entire firms. Companies have gone under trying to deploy both smartplant, PDS, and plant3d. Cadworx plant for the most part (except 2013-2014) hasn’t entirely bankrupted anyone that I know of in the denver market. But the software with best stability of current releases changes nearly quarterly.
        The last time the autodesk reps made their rounds and sat down with me, the senior product owner joked to me “you know what ACAD stands for? Always Control Alt Delete” all I could think was, this is your own damn product, man!
        ...if it wasn’t for Hexagon’s competition and use, I’m pretty sure they would have killed off the DWG platform a long time ago and started running everything on Revit’s engine.
        m20 Oil Stencil
          Originally posted by ForcedFirebird View Post
          80-90% of work is related to e30's, rest is filled up by 20+yr old BMW's.
          60 Degree V6 market drying up?
            Originally posted by LEANE30 View Post
            We have access to the newest versions of Cadworx Structure so I tested 2018 and 2019 (basically the same thing as 2014). They send us updates on new features but they're pretty pitiful (now they can add base plates to columns, woopdeee!) It is pretty obvious that their target market are companies that do basic layout "stick models" and send out all detailing elsewhere. We need something closer to a detailing package than a layout package (thus Tekla); when pressed the dev / marketing guys they made it really clear they would not be adding the things we needed for it to be viable.
            I have also tested the AutoDesk equivalent, which isn't horrible but it was pretty clunky - and AutoDesk license costs are insane. I also used to teach a class using their previous Structural Steel Detailer which was promising but also pretty horrible (and buggy), so they killed it off. Basically it being an Autodesk project and given their poor history of supporting and then just disappearing structural packages, we felt it was the wrong choice. Not being under their thumb is honestly a big advantage IMO.
            We have a bunch of Faro scanners, they work pretty well for us. We have scanned every single project pretty much for the last 8-9 years now. I can't say we've had any issues (except once when a scanner fell of a platform and had to be shipped to europe for repair). Laserscans are indispensable to how we work.
              Never really was a big market to begin with, and that stuff is more of an online service, the brick and mortar shop mostly caters BMW's (has been for years). Ben and I have parted ways for the most part, he moved back to Indiana and isn't using the site for any BMW parts/services anymore.
              john@m20guru.com
              Links:
