Gun Thread
  • varg
    Florida Turbo Man
    • May 2014
    • 3425
    #8911
    Yeah 450fps might not be enough unless you can consistently place shots very accurately, hard to do with a pellet pistol. I definitely can see where you're coming from with the pistol, I would like to take out some of the Bufos around here but my house is also in a development. The Iguanas are bad at my Mom's house and I've thought about picking up a cheap pellet rifle to take them out from the porch.
    IG @turbovarg
    '91 318is, M20 turbo
    • naplesE30
      • Nov 2007
      • 1841
      #8912
      450fps is honestly marginal for cane toads.Placement is a must for a humane kill, and I need to use the pointed pellets. I think for iguanas your gonna want to be 1100fps minimum, definitely would need to be supersonic. For an idea of power, my pistol is not strong enough to puncture the thicker plastic of a Gatorade bottle.
      • varg
        Florida Turbo Man
        • May 2014
        • 3425
        #8913
        I just learned that your cane toad and my bufo toad are the same thing
        IG @turbovarg
        • myinfernalbmw
          • May 2007
          • 1736
          #8914
          I just ordered up one of the surplus Beretta 81s that hit US shores in the last month. I take a lot of new shooters to the range and I guess these are one of the least intimidating things to shoot short of a.22lr. Based on how surplus guns go I know I'm going to regret not buying more of these to flip in a few years. I guess we'll see how this one looks when it gets here.
          • naplesE30
            • Nov 2007
            • 1841
            #8915
            Post pictures of it when it comes in. Who did you go through, Classic?
            • myinfernalbmw
              • May 2007
              • 1736
              #8916
              Will do.
              Initially I did but a couple of hours after I placed the order I saw two guys post up rusted out pieces of shit they got from Classic. I cancelled my order and put in an order at DK instead which ended up being the same price for a hand selected gun. It was probably a waste of $20 for the hand select, but it was the same price out the door and it sounds like DK is shipping faster and vastly better examples.
              • myinfernalbmw
                • May 2007
                • 1736
                #8917
                Picked up my 81 at my FFL today. I'm very happy with it. The slide has a few small dings and one freckle of rust that cleaned up with some oil, but the finish is otherwise perfect. The frame has some edge wear around the trigger guard as well, but I should be able to touch it up easily. The internals look brand new and I'd be surprised if it had more than 100 rounds through it in it's life as a prison guard.
                If AIM surplus finds more "select' grade guns I'll probably pick up a second. Should be able to get out and shoot it Monday so I'll update on how it runs.
                • Exodus_2pt0
                  • 5943
                  #8918
                  Need some recommendations for a accurate, subsonic, .22 HP.
                  The cci standard round nose I'm using isn't very consistent, and unless it is a head shot, it doesn't do the job well on squirrels.
                  No E30 Club
                  • TeXJ
                    • 1914
                    #8919
                    what are you shooting it out of? I assume you're shooting it out of a suppressor? If you are shooting it out of a pistol standard velocity should be fine.
                    I thought CCI was pretty good. I mean out of the ammo I use it seems to be the best.
                    I would then start buying different brands and seeing what your gun likes the most then.
                    1990 325is
                    m52b28
                    3.73lsd
                    g260 (1987 325is 5spd tranny)
                    • mrsleeve
                      • Mar 2005
                      • 16387
                      #8920
                      Growing up I NEVER had issues with 22LR for squirrel hunting, I used an at the time old Rem 581 bolt action 22 for the job, a 22LR in a good long barrel thats not been worn out should be fairly accurate inside 85 yards. Your not going to put every shot through the same hole with a 125 dollar 10/22 at 50+ years IME but I do agree that try some other ammos and see what your gun likes, in general CCI used to be the go to for rimfire, but I have had diminishing results with them for a long while now, so I have been using what ever was on sale when plinking with a 22lr and mine seems to shoot federals as well the CCI's anymore.
                      You guys with the reptile/amphibian issues in FL, look into a good .22cal Pellet rifle, you can get them shooting about 800fps with a 15-20gr pellet, if that wont dispatch a toad (unless its the size of a Trash panda) your going to have to look into powder driven projectiles. I would think those speeds and energies would also work pretty well an smaller to medium sized iguanas as well, and larger ones with head shots, a lot of guys use air rifles for pest control all over the pace and especially in places where traditional powder driven projectiles are all but banned (IE europe) hell I know a couple of guys around where I live that prefer the 22 pellet rifle around where I live to keep the ground squirrels in check, because its quitter (get more the one shot sometimes), and wont carry to the neighbors house as easy, and when you have urban California types moved in next door, the cops are called when gun fire happens.
                      Originally posted by Fusion
                      William Pitt-
                      • naplesE30
                        • Nov 2007
                        • 1841
                        #8921
                        I have had good success with federal automatch with my 10/22. It has been reliable and fairly accurate. However, it is not subsonic nor a hp..... but would certainly put down a squirrel humanely.
                        My little M17 pellet pistol is racking up the toads. I am up to ten now. I saw a big mamma jamma last night when walking the dog. Ran in to get the pg to take care of him.....and when I came back he was like a fart in the wind...gone. He will get his medicine tonight if I see him.
                        • Exodus_2pt0
                          • 5943
                          #8922
                          I'm using a ruger american .22 bolt action with my form 1 .30 can on it.
                          It's wierd, because if I shoot free hand, they usually drop. But I've taken a few shots when bracing against something and end up missing or wounding.
                          I'm sure the bolt action is more accurate than I am. So just looking to tighten up the groups a bit and go with something that will do some damage even if I don't hit vitals.
                          This post was prompted because the other day I snagged a squirrel that had evidence of not 1, but 2 pass throughs that had healed. I'm not looking to wound or cause unnecessary pain. So I want to find the most consistent, expanding ammo I can while staying subsonic.
                          I can be loud where I'm at, and often shoot Clay's with the shotgun. But, I prefer to stay quiet when I can.
                          No E30 Club
                          • roguetoaster
                            Biggus Tippus
                            • 7830
                            #8923
                            Impressive, sounds like air rifle injuries, normally a .22 hit on a fleshy bit will not be survivable for a small rodent. Also, an admirable goal to find a good mix of quiet and reliably deadly with other than a solid hit.
                            • mrsleeve
                              • Mar 2005
                              • 16387
                              #8924
                              I was thinking BB out of a .177 cal pellet rifle. I agree a .22 cal hit is going to be a mortal wound, powder or air driven
                              William Pitt-
                              • amyacker
                                • Sep 2019
                                • 3
                                #8925
                                Originally posted by Kilawin
                                Sig Sauer 320 .40 cal w/ night sights
                                Just wondering, why not in .40? I have one as well in 9mm and love it but considered the .40 back when I picked it up.
