Dyno session
  • Boosted E30
    • Dec 2009
    • 288
    Dyno session
    Bunch of us got together and rented some dyno time. Had 4 diffrent 24v swapped E30s so i figured id share with you guys.
  • Good & Tight
    • Apr 2004
    • 2057
    http://www.youtube.com/watch?v=7dGQj0HiqCI
    Really 186rwhp and 191rwtq on a M50TU. Is it stock..? Where those 3rd gear pulls...?
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    • F34R
      sLaughter
      • 12376
      Maybe that is CHP(Canadian HP) ?
      Account for 15% loss to the rear wheel with a standard transmission, it would be roughly 161 rwhp.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
        • 34844
        Its probably crank hp calculated from an estimated drivetrain loss.
        • IronFreak
          • Dec 2012
          • 3702
          I was skeptical about the first two, what threw me was the 296?hp s52.
          Instagram @rebellionforge
          • Boosted E30
            • Dec 2009
            • 288
            The dyno is SAE calibrated to sea level but the numbers do seem a little high by like 20whp.....
            • F34R
              sLaughter
              • 12376
              Of course it is high, the m50tu comes from factory with 189 hp@crank.
              Current cars:
              ~ '87 535
              ~ '06 X5 4.8is
              • Bullet Ride
                • Dec 2010
                • 598
                It did spin up pretty quick, so it was probably 3rd gear. In theory, gear ratio doesn't factor into dyno readings. However in practice, due to drivetrain losses, 3rd gear vs 4th gear pulls can vary by a few hp. As long as the dyno can collect data fast enough 3rd gear is safer because the roller speed ends up being lower. I'd be terrified to stand anywhere near the rollers when high hp cars are turning 140+ mph in 4th gear.
                • Boosted E30
                  • Dec 2009
                  • 288
                  No way, really?!?!
                  Yes the majority of the N/A cars were done in 3rd. Also i do not think there was any load on the dyno, it was just momentum.
                  The S52 has schricks, 540 throttle body, headers and full exhaust, 3.5" CAI with 3.5" maf, 24lb injectors and a tune.
                    • 34844
                    that's still not 296whp. That's S54 territory.
                    • Bullet Ride
                      • Dec 2010
                      • 598
                      ^As shown by the S54 that was on the same dyno
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        That's cam/headers/tune b25 numbers.
                        john@m20guru.com
                        Links:
