How to Achieve Zero Preload Video
  • yeaseth
    • Jul 2011
    • 302
    Do you know the best way to Achieve Zero Preload on your Anti-Roll bar?
    Check out Episode 7 to find out...
    https://youtu.be/-t4sVADarWI
    benvideoproductions.com
    http://www.youtube.com/watch?v=617yNrOrRfo&
  • yeaseth
    • Jul 2011
    • 302
    bump
    • Spyke
      • Sep 2012
      • 494
      Nice, clear and simple video
      Current_SeeDee 1972 e10 Luna 1975 e10
      Past___Veronica 1994 e36 Le-Ah 1987 e30
      • yeaseth
        • Jul 2011
        • 302
        Thank you sir, that's the goal I have with all my videos. Plus I know people attention span is low, like mine, so I make them as short as possible. Hit that subscribe button to support more short videos!
        • moatilliatta
          • 6158
          Those who are doing this in their E30 and have to do it repeatedly. AAF and AKG makes a nice ADJ rear link so you don’t have to unbolt the bracket.
          Thanks for sharing what a lot of people don’t do.
          @Zakspeed_US
          • ForcedFirebird
            • Feb 2007
            • 8300
            Nice video.
            We also make sure the bars move freely when disconnected from the end links. Often times the c-clamp for the bushings require a washer behind them. Since we run in a class that requires to pay for modifications in points, we use static links and use shims under them to get zero. Binding in the bushings will cause similar issues to preload.
            Keeping the bar level with the ground is also another point often missed. The e30 design makes this tough when lowered. Audi has a link that fits right in the stock location, but is about 3/4" shorter.
            john@m20guru.com
            Links:
