what type of mounts do you guys like?
  • coolasacuc
    • 383
    i will be investing in some trans and engine mounts soon.
    i had "race" urethane mounts on my 87 325is but it was 15 hp over stock, and i only auto-x'd with it.
    this car is a 90 getting a turbod M30b35 (370+ tq est.) and will be tracked only.
    i was looking at the solid alum mounts by UUC and wanted to hear if anyone uses them.
  • bataangpinoy
    • Jul 2008
    • 1636
    i use motor mounts in 80a poly.
    My feedback:
    http://www.r3vlimited.com/board/showthread.php?t=186328
    http://e30tech.com/forum/showthread.php?t=74911
    Instagram:
    @gears_n_glory
    @functionmotorsports
    • coolasacuc
      • 383
      i had the 75d.
      is there mutch of a difference there?
      • namsayin
        • 1568
        I am wanting to know this as well! I need some stiff shit for my s54 powahhh
        • kishg
          • Sep 2006
          • 2624
          akg 75d all around.
          '12 F30 328i Sport Line
          '91 SpecE30 #523
          '00 Ford F-350 Dually Tow Vehicle
          BMWCCA #360858 NASA #
          128290
          • coolasacuc
            • 383
            think i might machine my own solids
            anyone out there done this
              • 34847
              Originally posted by coolasacuc
              i had the 75d.
              75d is much harder than 80a
              75d is pretty close to delrin. The only thing significantly stiffer would be aluminum. I think AKG sells those too.
              • JGood
                • Jan 2004
                • 7959
                AKG 75d all around here too. I pulled them off after 15 track days and they still look new, they even have the circular grooves on the mounting surfaces.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • coolasacuc
                  • 383
                  yeah i loved the 75d's
                  my concern is having nearly double the tq. will my 75d still feel like 75d's or will they feel a more challenged and inadequite.
                  anyone using 75d or higher with high tq
                  • SamE30e
                    • Sep 2007
                    • 4319
                    Since you're tracking it only, you could go solid. If it even touches the street you'll want to shoot yourself. I suggest reinforcing the subframe if you're going to go solid with that much torque.
                    1985 325e 2.8 Turbo VEMS
                    • etxxz
                      • Feb 2006
                      • 2085
                      IE yellow poly mounts have done an awesome job on my street/track hybrid... although people advice against them because some have experienced them melting. My headers are heat wrapped just in case. engine = s52. feels awesome, don't vibrate at all. Stock e36M tranny mounts though, the IE poly mounts made my car feel like a 240hp'd blender.
                      edit months later. The IE mounts did melt, even with heatwrap.
                      No more e30s for me.
                      88 black BMW OBDII 332is dedicated track [sold]
                      88 BMW OBDII bronzit 332is [RIP 03/08]
                      91 BMW 325i [sold]
                      86 Corolla 'Ae86' HB 20v trd [sold]
                      http://youtube.com/watch?v=pTj7Hn9v5Rs
                      • craz azn
                        • 752
                        Should be common knowledge to reinforce the front subframe on any e30 that sees track use, regardless of mounts/powertrain setup.
                        Rippin' Proper | Youtube | Vimeo |
                        • SamE30e
                          • Sep 2007
                          • 4319
                          Some people don't know.
                          • coolasacuc
                            • 383
                            yeah im already stocked up with braces, tower reinforcements, so on.
                            guess ill stay with the pollys and i could always upgrade. I would rather abuse new $50 bushings than my old expensive drivetrain.
                            • itsbrokeagain
                              • Jul 2008
                              • 199
                              I bought some IE mounts not too long ago off a member here (got a good deal on them) and they totally eliminated all the slop...I felt them the first day I put them in, but I forget they are there now. Almost feel like stock.
