Bending Struts
  • chet3215
    • 30
    Bending Struts
    Any words of advice? Not on me doing the bending but are there any drawbacks i should know about?
  • SkinnyVT
    • Nov 2008
    • 391
    what are you talking about? Are you doing this to get more camber?
    '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      http://store.nexternal.com/shared/St...unt2=134711861
        • 34839
        it works, the only real drawback is it's not adjustable. whatever you get is what you're stuck with.
        • chet3215
          • 30
          Thanks, I use camber plates allready so getting things to match up when done shouldn't be a problem and i know who can do the bending. I was hoping i could find someone with experiance. I just want to know what to expect and if there might be reliability issues.
          • SkinnyVT
            • Nov 2008
            • 391
            how much camber are you looking to get if you already have plates? >3.5? Have you checked the temp of your tires to confirm you actually need more?
            • Massive Lee
              • Sep 2006
              • 6785
              Problem with bending struts is that the rubber will often contact the strut.
              massivebrakes.com
              • Wh33lhop
                • 11705
                This is what I'd be concerned with. You typically want to fit as much rubber as possible between your fenders and your strut tube, bending the housing will decrease the max possible tread width.
                paint sucks
                • chet3215
                  • 30
                  Thanks, i will have to do some figuring and see if my current tire setup will work with the extra 1.5 degrees negative camber i would like to gain with the bending process. I hope i havent forgotten to much geometry from my highschool days.
                  • 36brua
                    • 689
                    strut is bent where ? upper part of strut shaft ? Thnx
                    My CA legal M60 swap
                    The happening in our garage
                    • chet3215
                      • 30
                      its bent at the base of the tube just above where it goes into the cast knuckle
                      • Massive Lee
                        • Sep 2006
                        • 6785
                        Yup. Because if it were bent at the top or center, the insert wouldn't fit in anymore ;)
                        BTW after the strut is bent, it is a good idea to gusset it.
                        massivebrakes.com
                        • JGood
                          • Jan 2004
                          • 7959
                          What is the approximate clearance change for a 15" wheel with 1.5 degrees of strut angle change?
                          e30 restoration and V8 swap
                          24 Hours of Lemons e30 build
                          • Jean
                            • 18228
                            I had this done on my 03 1.8t that I didn't care much for...got -1.5 iirc on each corner w/o camber plates. But I don't think I would do it if you had good shocks etc... seems a little hokey...
                            • 36brua
                              • 689
                              Thanks for the info
