E28 Race Car Project Begins
  • Nsquared97
    • 1656
    #46
    Very cool, keep up the good work!
    • Kershaw
      • 11822
      #47
      you need another 3 years to finish this.
      AWD > RWD
      • MikeLenoch5
        • Apr 2012
        • 227
        #48
        You seem twice as intelligent and mature as your age would suggest! Good on ya!
        • MikeLenoch5
          • Apr 2012
          • 227
          #49
          I'd be happy knowing HALF as much as you seem to, Spence. My God, I'm reading your MyE28.com thread!
          • downforce22
            • Aug 2009
            • 3192
            #50
            been following the e28 thread for almost a year now, just not registered over there. Looks like you're finally back to getting some work done on it!
            • sbeckman7
              • 94
              #51
              Hi everyone,
              So... I've been dealing with a fantastic flu since Monday so I added more detail to the CAD model. Newly added are 17" Style 5 rims, rear subframe, halfshafts, diff, front and rear suspension, driveshaft and flex disc, brake rotors, revised gearbox with mounts, and a steering wheel to top it off. Here are some shots. This would also be a good time to explain that I've modified the frame, again. I dropped the seat to the floor, sat down, and realized that it felt like a good driving position, so I lowered it and the roll bars 5" and the sides of the frame by 3". Less weight, lower CG, and it looks more badass I also adjusted the track as the wheels were a little too far in.
              • Pl3wA
                • 1589
                #52
                ugh... (jizz)
                • tinkwithanr
                  • Jun 2010
                  • 377
                  #53
                  Nice Work! Are you planning for any more support on the front suspension points? The plates by themselves look a little skimpy, especially only being supported on 3 points.
                  Tinker Engineering - 2014
                  Mica - 2000 BMW 323i - The one that started it all
                  Fiona - 1975 BMW 2002 - The Definition of Project Creep
                  Heidi - 1988 BMW M5 - The piece of BMW history
                  Silvia - 2013 Subaru WRX - Stock, for now
                  • sbeckman7
                    • 94
                    #54
                    They will be gusseted and additional material will be added on the tops of the tubes to seal them and better secure them to the plates.
                    • sbeckman7
                      • 94
                      #55
                      Time for an update:
                      I have been very fortunate to receive a Job in this economy; I now work at Peet's Coffee and Tea. Unfortunately, I may have to quit soon... Because I just got hired as a Technician In Training at Aston Martin!!! I was beside myself with joy when I got the call; it felt like one of those surreal moments that's a half dream. I start this Friday.
                      Back to the BR1. I've been in contact with a machine shop called Ellsworth Brothers that does all the heads from DINAN as its right across the street from the HQ. Not only were they the most thorough, offering a 3 angle valve job, but they were also the cheapest at $225 per head! I'll have them done once I'm a little further along with the frame and have more money in my bank account :alright:
                      I was about to weld the transmission tunnel in place when I decided to do a test fit of the Sparco's and found it was not a good fit with the tunnel designed the way it currently is. The seat touches on both sides of the frame so I'll be modifying the center tunnel to more of a "Y" shape instead of a "V". Here are the pictures to show the clearances, or lack thereof. You can also see the structure I tacked over the bell housing. I am concerned about those clearances as well: There is currently 3/4" of room between the top of the bell housing and the structure directly above it. I am planning on shaving down a few of the gussets on the bell housing to allow for more clearance. I don't think the amount of material I will remove will affect the strength of the piece, but I'll wait to mess with it until I have the transmission bolted up and ready to go.
                      • MattAvino
                        • Jan 2011
                        • 2147
                        #56
                        amazing.
                        Did I say amazing?
                        E30 buildy things
                        http://www.r3vlimited.com/board/showthread.php?t=195286
                        • goarmy
                          • Nov 2011
                          • 622
                          #57
                          Basically you are building your own custom roadster which is comon but RARE. And using a bmw power. I aways wanted to build my own roadster. I hope you finish it all the way to the end
                          • sbeckman7
                            • 94
                            #58
                            Thanks for the comments guys, I'm glad it's well liked!
                            Not sure what you mean by the first sentence but thanks haha. I do plan on finishing this project as I am extremely determined to bring it to college.
                            • sbeckman7
                              • 94
                              #59
                              New transmission tunnel. My clutch/flywheel setup should be shipped by the beginning of next week!
                              • PeteD
                                • 982
                                #60
                                WOW. Great ambition. I hope you can finish it before you start your tech school. Pulling up to day 1 at Aston Martin tech in your custom built roadster would really set the standard for the class.
