How fast is a 24v E30 on a road course?
  • kishg
    • Sep 2006
    • 2624
    definitely tighten the nut behind the wheel first :)
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
    • JJ1
      • Oct 2009
      • 176
      s2000 has superior chasis with double a-arm suspension front and back. Its a newer car with less to maintain. I raced my friends s2000 with no cat vs my s52e30 with 16lb flywheel and I was barely any faster in a staight line. All that being said, an s2000 is a better track car with equal drivers but an s52e30 is just so much more bad ass than a little honda convertable. Just my opinion.
      • FreedS4
        • 752
        Just for reference, at our most recent Auto-X event (a high-speed course), there was a pretty good mix of cars and drivers. In my stock motor e30, I was running a full second faster than a fellow M3 e30 and 2-5 seconds faster than cars that SHOULD have been faster (i.e. Vettes, Camaros, S2000s). Some of that can be attributed to the fact that I've got Billy Sports and H&R Race springs, but more of it is attributed to the body behind the steering wheel.
        • Charlie
          kid tested, administrator approved
          • 6686
          It's a lot easier to drive lazy with an M50 than an M20, a vanos motor has tons of torque at pretty much any RPM, and you can definetly "drive" the car more vs having to maintain momentum at all times.
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • mach schnell
            • Apr 2008
            • 1059
            What about with the extra weight of the M50?
            Does it make the E30 a pig?
            • Skafrog
              • 1730
              yes. +50 lbs makes the car undriveable. Mine actually doesnt turn anymore, it just slides along the wall.
              Properly built e30 DM/CM cars are around 70/30 weight distribution.
              NASA MidSouth TT Director / GTS2 #018
              Mods: Coastal PS Fluid, 10w40 Oil
              Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
              • Massive Lee
                • Sep 2006
                • 6785
                Are you sure about that? I corner weighted one at 55/45 (with S14).
                Our e46 racecar is 50.5/49.5 BTW
                massivebrakes.com
                • Skafrog
                  • 1730
                  Yup. If you get an e30 down to 2000 lbs, they are close to 70/30. Maybe 65/35.
                  I know the corner weights of our old DM car and a few more that used to run in the SE.
                  • LivingLegend06
                    • Dec 2006
                    • 1604
                    A 2000lb E30 with 70/30 weight distribution has 1400 lbs on the front axle.
                    A Stock 2700lb with the stock ~50/50 distribution has 1350lbs on the front axle.
                    How exactly are you ending up with more weight in the front in full race prep than in stock trim?
                    I'm with Lee and the guess of 55/45.
                    • Wh33lhop
                      • 11705
                      Stock weight distro is about 53/47 plus another 50 or so lbs on the front axle for an M50.
                      paint sucks
                      • iflytii
                        • Jun 2004
                        • 482
                        I won the GT2 championship last year with my local race series running a S52. My car weighed less than 2230 lbs. Hardly a pig!
                        As far as balance, when my car was CM legal it was nowhere close to 70/30. I'll have to find my data to be exact but off the top of my head I was around 54/46.
                        I need to re-weigh to see exactly where I am now with my LS swap.
                        • JGood
                          • Jan 2004
                          • 7959
                          My 2400lb e30 is exactly 55/45. I'd be curious how you can take that much more weight out of the rear to bring it to 70/30, or even 65/35. I don't even have a full cage, fuel cell, wing, or big tires back there. Up front I'm basically stock under the hood, with the exception of A/C components being removed. Most of the other weight removal (lexan, heater core, body panels, sunroof, p/s, wiring, etc...) is either in the center of the car or above the front axle. And most of the weight to be added is in the rear.
                          e30 restoration and V8 swap
                          24 Hours of Lemons e30 build
                          • rThor432
                            • Feb 2007
                            • 3907
                            My S52 car weighed in at 2,450 lbs with a 53/47 weight balance. Standard sheet metal body. That was when I still had some AC pieces, ABS, and some other unnecessary hardware. Just wanted to post some solid info.
                            • 2002maniac
                              • 4260
                              Fast enough to pass a porsche turbo or z06 vette, and slow enough to get passed by a civic or miata.
                                • 34839
                                lol. that sums it up.
