What to do for brakes short of a Massive kit?
  • 2002maniac
    • 4260
    #46
    did you change your pads yet? ATE blue wont be the weak link if you are still running HP+ auto-x pads.
    • Bishop
      • 4913
      #47
      I haven't changed pads yet, and the fluids going to stay ate blue, but I'm also going to rebuild the caliper which I'm guessing is going to get messy, so I'll re-bleed with super blue
      PM me for detailing services in the Longmont / Boulder Area in Colorado!
      Originally posted by DTM190
      "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
      • red911turbo
        • Oct 2006
        • 222
        #48
        Originally posted by Massive Lee
        Ate Blue brake fluid is a good product. But it is pretty old technology and basic. Blue or Gold (the same specs, different colors for flushing) will work great on cars that don't have major overeating problems. The e30 on stock brakes is known for the excess heat it packs. Therefore, I suggest using an even higher grade of fluid. But beware, it can become quickly costly. Pentosin makes some good stuff, as well as Motul with its RBF600 (dry boiling point of 593°F and a wet boiling point of 420°F) or Castrol SRF (S stands for $$$$) (dry boiling point of 590°F and a wet boiling point of 518°F) but is silicone-based and will require all new hydraulic components. Compare especially the wet boiling points of Ate's Blue (dry boiling point of 536°F and a wet boiling point of 396°F).
        Which Pentosin product are you liking? Super dot 4 or their Racing fluid?
        E30 325i 24v, E36 M3/4/5, MK2 GLI 16v, NA8 Miata
        Prestige Auto Repair
        Mercedes-Benz|BMW|MINI
        prestigegermanrepair.com
        • SkinnyVT
          • Nov 2008
          • 391
          #49
          Just curious as to why you seem set on using ATE Blue? Is it just due to the price?
          '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
          • Bishop
            • 4913
            #50
            No, I have a can and a half leftover still....
            • Massive Lee
              • Sep 2006
              • 6785
              #51
              Pentosin Super DOT 4 is OEM on newer cars among German car manufacturers. It is made to be relatively less hygroscopic than a performance fluid, mainly for people who bleed their brakes every two years... The Racing fluid is better for track duty.
              Here's a great chart.
              massivebrakes.com
              • carnurd
                • Jul 2009
                • 110
                #52
                Lol I have the same hahaha...win...
                1991 BMW 318is Track Car-NEEDS ITBS AND STANDALONE!!
                1997 BMW 328i Daily Driver-like buttah..
                • kuzimmer
                  • Apr 2008
                  • 93
                  #53
                  How long has the 1/2 can been opened? I generally don't use anything that's been opened more than a couple months, but I'm paranoid.
                  Kurt
                  • Bishop
                    • 4913
                    #54
                    It's only been open for a few months
                    • briansjacobs
                      • 1278
                      #55
                      use it or loose it!
                      Brian Jacobs
                      • Bishop
                        • 4913
                        #56
                        We just used some of it on my friends car, and the rest will be going into my car when i rebuild and rebleed my calipers
                        • Mr Two
                          • Jul 2008
                          • 590
                          #57
                          Let me just chime in to say that HT-10s are great pads. I've never had any noticable fade issues. This was at Nashville Superspeedway's road course though, so ymmv.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            #58
                            I've been useing ATE blue for years at the track. No issues for me
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • kishg
                              • Sep 2006
                              • 2624
                              #59
                              if you bleed/flush often ATE blue should be fine on an e30.
                              '12 F30 328i Sport Line
                              '91 SpecE30 #523
                              '00 Ford F-350 Dually Tow Vehicle
                              BMWCCA #360858 NASA #
                              128290
                              • Jean
                                • 18228
                                #60
                                I gave hawk hp+ a shot a few weeks ago and they are more than enough for doing autox events. Ran on dot r tires and used motul rbf600 fluid, rock solid pedal and no fade during enduro event. I also used this same fluid before in my 04 r32 with stock 13"? rotors and carbotech pads, no fade also at Thunderhill track all day (about 2-2.5 hours of hpde). IIRC speeds were in the 120-130mph range on the front straight into turn 1 down to about 60ish??
