What to do for brakes short of a Massive kit?
  • carnurd
    • Jul 2009
    • 110
    #61
    Originally posted by kuzimmer
    How long has the 1/2 can been opened? I generally don't use anything that's been opened more than a couple months, but I'm paranoid.
    Kurt
    Well you do live in probably the wettest state in the US it might be a close tie with WA. Down here in Tucson, AZ its as dry as a place can get...
    1991 BMW 318is Track Car-NEEDS ITBS AND STANDALONE!!
    1997 BMW 328i Daily Driver-like buttah..
    • Bishop
      • 4913
      #62
      CO isn't bad at all really either. Is there any way to "inspect" the fluid? I don't imagine there is, but I should be tackling my brakes here in a week or so.
      PM me for detailing services in the Longmont / Boulder Area in Colorado!
      Originally posted by DTM190
      "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
      • 325ix
        • Aug 2009
        • 7783
        #63
        I would just buy new fluid to be on the safe side.
        • Bishop
          • 4913
          #64
          Or open the other can that's still sealed...
          • carnurd
            • Jul 2009
            • 110
            #65
            Ding ding ding ding.... lol
            • 325ix
              • Aug 2009
              • 7783
              #66
              ^Good idea, I just wouldn't use an already opened can.
              • Massive Lee
                • Sep 2006
                • 6785
                #67
                Here's a bit of logic.
                - Scenario A
                A new can of fluid is opened. Some of the content is used, the rest remains in the can. After being opened to air for 3 minutes, the cap is put back on. No moisture goes thru the steel/plastic container from now on. Therefore, the fluid was exposed to potential moisture for only 3 minutes. How much moisture was absorbed by the hygroscopic brake fluid? Most likely an infinitely small amount.
                - Scenario B
                The fluid in the braking system absorbs moisture thru the brake and clutch rubber lines, 24hr a day. Then the fluid reservoir cap also is opened to moist ambiant air as there's a small hole in the cap.
                Conclusion: make your own. But personally, I have no problem using brake fluid from a container that was opened a year ago, as long as it stayed closed the whole time. Anyway, more moisture will have found its way into the fluid thru the hydraulic system.
                massivebrakes.com
                • Bishop
                  • 4913
                  #68
                  lol, that's what I was thinking but wasn't going to say because I'm sure there's some e-expert willing to crucify me.... I'll be using fluid from the old can because I used it once, sealed it, and it's been sitting in a box in my basement since.
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    #69
                    ... because I'm sure there's some e-expert willing to crucify me....
                    Many e-experts in the tech section, and so many virgins in Your Favorite Pictures *NWS* section... :mrgreen:
                    massivebrakes.com
                    • carnurd
                      • Jul 2009
                      • 110
                      #70
                      LOL lee you make me laugh and that^^ is so correct. I feel a metal can(ate blue) as long as its capped even if its open for 30 minutes while you bleed your brakes(in a dry area like Tucson) you will get nearly no moisture into that can. And you are also correct any moisture that is going to be getting into the fluid is going to be coming from the fluid sitting in the car.
