do it, who cares about spacers.. they work fine. don't know why people get so worked up about them, they'll basically let you fine tune the offset to fit as much tire as possible. you'll be running studs anyway, not like wheel changes are going to be an issue. :)
949 Racing 15x10 wheels
I will :) Plan on taking my car to a shop this week see what it will cost to widen my fenders to get an idea on cost.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
I have been curious about these wheels as well. I run the 275 hoosiers.
I think this wheel is like 5.5 ofsett with 10mm spacers
You will need an honest 2 inches to cover the rubber and also trim the front and rear of the front fenders or as my friend did as he has plastic bumbers space them out a lil.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713Comment
^ I sure hope Jean's car doesn't look like that! Looks like a Mexi-special.Comment
on one hand it looks kinda badass, on the other hand it needs some help! :)
heh, I hope you were just filling up. I can't imagine how many street miles a set of hoo-hoos would get.. lolComment
No, I am looking at getting the fenders cut and extended like this - that way the front/rear valances/bumpers don't need to be modded...
Spoke with 949racing today. I need to take some measurements and see what the heck is going to be require to make these work.
Any ideas on the cost of 20+mm spacers that will also correct the center bore difference?
Also looking into bogart options as well.. I would really like a direct fit (in terms of offset/spacing/center bore) as I am afraid having to run thick spacers + possibly rings will just drive the cost up vs. getting a custom made wheel done?
I don't know.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
I'd think maybe a couple hundred for the spacers, even custom, so you wouldn't need rings?
the thing about spacers vs custom wheels is wheel replacement. say you bend one, or it cracks, or something happens.. it will be a lot more expensive to replace.Comment
Mexi special HUH I am sure my suspesnion is worth more than your car LOL
Yes I drove home from an event cause the tires were dead. It was quite fun.
I did the stud conversion. I run H&R spacers which are hubcentric and the studes take care of the rest. Thus why they accorn lug nuts. Oh and my wheels are spin werks. They are not steel. They dont weigh much either may 13lbsAny ideas on the cost of 20+mm spacers that will also correct the center bore difference?
I don't know.Last edited by bmwguy325is; 07-19-2011, 09:32 AM.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
Thanks but we are talking specifically about 15x10.
Are you running spacers with center bore change or running rings as well?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
You keep mentioning the wheel width, when its the tire width thats important when talking about fitment. I think you said you wanted to run 275's in an earlier post. Is that square? My biggest concern would be clearing the inside of the wheel well while turning. I had trouble running 235s in front, but only had a fender roll. I figure you have to run between a 30 to 35mm spacer in front to not lose any turning radius depending on the tire model you go with.Comment
I am running v710 225/50 on 15x8 right now and the tire is wider than the 225 street tire and clears w/o problems even with fender lines..no spacers and such but this is on trm wheels. This is a 9.2" section width, 9.0" tread width and 23.7" diameter tire.
There aren't exactly many choices for 275x35x15...
Specs on the A6 are here
10.8" section width, 10.1" tread width, 23" diameter.
