Is there a track safe Anti-Freeze?
  • Earendil
    • 1662
    And I do specify anti-freeze, and not coolant. I started doing HPDE this summer, and out of respect for the track (and distrust of my car) I started running pure water instead of coolant. Well, winter is coming to the north cascades again, and my car should not be sitting outside with water in it.
    Is there track safe anti-freeze that doesn't cost an arm and a leg? Or is the easiest thing to buy a bunch of anti-freeze, dump it in, and do a flush come spring?
    Thanks!
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
    There is no track safe antifreeze. The right thing to do is to fill the system with anti-freeze mix when freezing weather is imminent and change to water & WaterWetter (or equal) once the danger of a freeze has past. On a related note, if the car has an AFFF system the bottle needs to be protected from freezing. Either bring it inside or use a heating pad. I use a battery heating pad for this.
    • Earendil
      • 1662
      Cool, thanks for the quick info. I failed for half an hour on google finding a solution, so I asked. I'm glad I didn't burn another half hour looking for a solution that doesn't exist! Thanks! :)
      Cheers,
      Tyler
      • Nsquared97
        • 1656
        Stupid question, but what is an AFFF system?
        • SoloSol
          • May 2007
          • 68
          Google says its a fire system. I didnt know either.
          • UNHCLL
            • 8790
            If it is purely a track car, I recommend using RV Antifreeze over the winter. It is not as harmful if you spill some when flushing/changing the system, and you can easily store it and use it for multiple seasons if the car is just sitting un-used.
            Below the radar...
            • TobyB
              • 5298
              oh, and use an additive with your water, otherwise, your head will become swiss cheeze... (water wetter works)
              t
              • devon.818
                • Feb 2011
                • 2937
                everyone i know who has a sportbike has done atleast one track day. they all start freaking about the antifreeze and track prep.
                some use water, most use a mix of water and water wetter. 60 water 40 wetter
                • Jaxx_
                  • Dec 2009
                  • 1880
                  that ratio doesn't sound right at all.
                  • 5Toes
                    • 9836
                    Industrial insulation manufacturer, foam insulation fabricator, urethane insulation, isocyanurate, foamglas, perlite, styrofoam, cellular glass insulate, phenolic foams, refrigeration systems, stainless steel tubing insulator, pvc jackets, pharmaceutical, chemical, petrochemical, underground insulation systems, by Extol of Ohio, Robin DeGraff.
                    If it doesnt get below 15 Fahrenheit a 25% mix to 75% water should be fine... and that might be okay at a track day???
                    • Justin B
                      Sikky Nar Nar
                      • Mar 2005
                      • 4273
                      I would only run straight water on a track day. If your shit is going to freeze so hard it might crack the block at night before hand, there's ways around it, or dont plan on it.
                      • djjerme
                        • 5082
                        two words: Hard Blok
                        2016 Ford Flex
                        • priapism
                          • 1182
                          No it doesn't. You're supposed to run like, a couple of capfulls.
                          -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
