E30 325 , how do I lose weight
  • TobyB
    • 5296
    2460 and no cage? meh...
    t
    • mitchlevy7
      • Aug 2011
      • 672
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • Jean
        • 18228
        iwantspeed - nice! I am at 2500lbs with full interior and m30b35 swap, half a tank of gas, no a/c compressor, no spare tire/jack.
        • iwantspeed
          • 3164
          thanks thats pretty impressive.
          are those numbers with aftermarket seats?
          im curious on what a slider and recaro seat weigh
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • Eric
            • 5142
            How the heck do you guys loose that extra 200-300 lbs? I have a euro S50B30 which i'm guessing weigh's more than the M20, but I feel that my car is a bit heavy still!
            as it sat on the scales
            Removed:
            -all tar
            -power steering
            -ABS
            -all HVAC
            -all interior
            -foam from the dashboard
            -swiss cheesed bumper cores
            -smaller battery (need to go smaller)
            Possible gains?
            -gut the doors (4 door) w/ lexan on the back sides
            -get rid of steel hood/trunk/bumpers
            -lighter wheels (current combo is 51.8lbs a corner vs. 45lbs front & 46lbs rear) that's 25 pounds of unsprung weight!
            -remove e-brake. I have aluminum hats and steel rings for the ebrake, so this could shed another good chunk of unsprung
            -trim excess steel from unused section of the fenders.
            -lighter exhaust (in the works)
            -ditch the airbox for a big carbon one
            -trim down the wiring more
            Am I missing any simple things?
              Is the sun roof still in the car? It and the cassette are about 40lb and that is weight that is up high.
              • VinniE30
                • 2113
                Removed:
                -all tar
                -power steering
                -ABS
                -all HVAC
                -all interior
                Possible gains?
                A big part of it is that heavy euro s50. That's the heaviest 24v engine BMW has ever made, heavier than the US e36 ones and the s54 as well. And your front to rear weight distribution shows that. I would look for ways to remove weight from the front if I were you.
                Zinno '89 <24v swap in progress>
                • Eric
                  • 5142
                  Yes, it's definitely gone!
                  Hmmm, sounds like I need a carbon air box for sure! Do you by chance have the weight of a s50b30? I have never been able to find a good weight.
                  • VinniE30
                    • 2113
                    Check out my engine weights thread:
                    I discussed what has to be done to accurately compare engine weights and which are more credible and less credible sources..
                    My comment about the euro s50 being the heaviest was based on the BMW OEM parts weights on bmwfans.info
                    The weights on bmwfans.info(find the car then find the part "short engine"), while they don't include everything attached to the engine, are a good way to compare weights, since the same parts are included in that weight for different engines, so it's a fair comparison, and in my opinion, a lot more credible than other sources. And you can just look up the weights for other engine parts on that site (like the intake manifold for example) to compare everything down to the weight of each individual part and add them up.
                    • Thizzelle
                      • 4422
                      Originally posted by BeemerBuyer
                      you guys are pussies. This is how its done.
                      I got to drive the hell out of this thing last weekend at a private track day. OMG it was a riot. So awesome, you had to have been there. Its got everything you need, nothing ya dont. I'll have some videos up soon.
                      forgot to remove the arm rests, door card clips, sound deadening all around the interior, e-brake handle, shift knob, rear of seat, seat hand lever, even the door latch you can just push and pull on the metal rod.
                      "I wanna see da boat movie"
                      "I got a tree on my house"
                      • djjerme
                        • 5082
                        Start with a Diving Board car instead.. They are lighter. As mine sits in PRO3 trim, with the tar still in the main compartment, and trunk, lexan side rear quarters, 3/4 tank of gas.. 2548. So I am going to have to ADD weight to make the class min.
                        2016 Ford Flex
                        • E30Savage
                          • Jan 2009
                          • 208
                          I second the sound deading. That stuff weighs a ton. So get some dry ice, a hammer, and have at it.
                          oh and all that other shit you don't need.
                          My stuff for sale
                          http://www.r3vlimited.com/board/showthread.php?t=229541
                          • E30RedtopSR
                            • 202
                            I stopped eating cake.
                            And I put an all aluminum japanese engine in the car too.
                            Just sayin is all.
                            • Fusion
                              • Nov 2009
                              • 3659
                              Look into FG hood/fenders. I got all bits some time ago and that hood is damn heavy. Though the FG one I got even has the structural parts and hinges and looks 99% oem. Fenders aren't so much weight loss, but the fiber ones are featherweight.
                              Anyone want less in the rear, look into replacing the trunk hood. If you want to see what it weighs, just undo the springs and try for yourself. That fukr is almost as heavy as the front.
                              • 10Toes
                                Me Father Was A Tree
                                • Jan 2008
                                • 61222
                                More than an S38?
