BMW E30 Carbon Fiber Roof Skin Complete
  • Northern
    I like cupcakes & sh!tboxes
    • 5253
    If it only weighs 15 lbs, I bet you could still shave 10 off. And that's at the highest point in the car too.
    Originally posted by priapism
    Originally posted by shameson
    • qwerte
      • 32
      True.
      But you're not going to see savings like that with products that Ary/EuroStop/DTMFiberwerkz produce.
      • 240zs30
        • 583
        I thought I had seen this before. That looks pretty nice but the labor/cost/weight saving might be off. Why not just a weld in plug? If you remove a significant part of the roof and its for a "race" car you obviously might want a roll cage etc to help structure anyway.
        So fab or welding skills will be required anyway.
        • ///M42 sport
          • 3952
          Originally posted by qwerte
          True.
          FUHRAZE!! also its a good time to molest completely good e30's increasing stock e30s value
          • Nsquared97
            • 1656
            Not sure I'm on board with bonding carbon to steel though.
            Believe me when I say that, if done right, you can bond carbon to steel/aluminum for incredibly strong results. I've built suspension arms for formula cars that are aluminum and carbon, and held together by nothing more than epoxy, and they worked very well. We also used carbon shear panels in places of steel tubes in the chassis to make it both lighter and stronger.
            • F34R
              sLaughter
              • 12376
              I have plans to do this in th future. I would be in at some point.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • IronFreak
                • Dec 2012
                • 3702
                I'm just saying that an expensive 10lbs. I would make sure I had every other weight savings advantage covered first. It's a neat concept but man, I don't think I could pull the trigger.
                Instagram @rebellionforge
                • Northern
                  • 5253
                  Its not strength I'm worried about, its steel to carbon contact causing a galvanic reaction.
                  I suppose it would be easy enough to lay down a layer of glass on the car for a barrier and bond the roof to that though.
                  • Thizzelle
                    • 4422
                    carbon fiber vert top would be dope
                    "I wanna see da boat movie"
                    "I got a tree on my house"
                    • oliver.r
                      • Mar 2012
                      • 3839
                      boom
                      • IronFreak
                        • Dec 2012
                        • 3702
                        ^^^Did they make that? Where was it sourced from?
                        • oliver.r
                          • Mar 2012
                          • 3839
                          i haz no idea
                          • Spyke
                            • Sep 2012
                            • 494
                            I would be most worried about the typical DTM Fiberwerkz fitment issues, but it would be a cool idea.
                            Lots have talked about producing it, nobody has really ever done it except for a few skilled people that did just one for their own car. It's a big challenge, and you would have to do an amazing job from start to finish, no corners cut, to pull it off.
                            Current_SeeDee 1972 e10 Luna 1975 e10
                            Past___Veronica 1994 e36 Le-Ah 1987 e30
                            • bmw325csi
                              • May 2007
                              • 4045
                              That's an e46 d0e
                              harry/harout
                              • Kev
                                JMP Autowerkz
                                • 1575
                                Roof is from Bimmerworld.
                                "Hard Work Pays Off"
                                1991-bmw 325i (R3vvd)
                                1990- 325 (mpowa)(GC)(track)(beast)
                                1988- 528e (daily driven when track car broken)
