Pikes Peak 201(5)
  • Northern
    I like cupcakes & sh!tboxes
    • 5279
    #136
    Still lurking here, keep the updates coming.
    Originally posted by priapism
    Originally posted by shameson
    • Jeff Schaadt
      • Jul 2013
      • 141
      #137
      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
      Ok, that's better
      WMMFT Racing/Condor SpeedShop/BimmerHeads
      • Jeff Schaadt
        • Jul 2013
        • 141
        #138
        Motors pulled apart, Marc Williams at MW performance is going through it. Everything looked good, new rod/mains bearings going in.....piston rings be here shortly.
        • Jeff Schaadt
          • Jul 2013
          • 141
          #139
          http://
          Brake rotor cooler I built last weekend.
          • Jeff Schaadt
            • Jul 2013
            • 141
            #140
            http://
            Hard to see, but you get the idea.
            • silence
              • Jun 2007
              • 1824
              #141
              Did you water-jet them?
              •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
              •• Rear Subframe Bushings • RTABs • Facebook ••
              • Jeff Schaadt
                • Jul 2013
                • 141
                #142
                Plasma..... Searched E30 brake coolers, said to myself, yup, I can do that....just ripped off, I mean, used other designs as an example. TIG welded 3" exhaust tubing.
                • silence
                  • Jun 2007
                  • 1824
                  #143
                  they came out nice.
                  • Jeff Schaadt
                    • Jul 2013
                    • 141
                    #144
                    Motor should be ready in a week-ish or so, Marc Williams at MWPerformance said everything looked really good, going with new rod, main bearings and new piston rings, water pump, timing belt and a BimmerHeads "I" head......will be getting some other goodies from KAMotors, injectors, oil filter relocation kit etc.....ready to get this thing together.
                    • Jeff Schaadt
                      • Jul 2013
                      • 141
                      #145
                      http://
                      Went with VHT high temp Blue.
                      • Jeff Schaadt
                        • Jul 2013
                        • 141
                        #146
                        http://
                        • Jeff Schaadt
                          • Jul 2013
                          • 141
                          #147
                          http://
                          Got the Lump back.
                          • Jeff Schaadt
                            • Jul 2013
                            • 141
                            #148
                            http://
                            • Jeff Schaadt
                              • Jul 2013
                              • 141
                              #149
                              On the plane, headed to Colorado again.....Pikes Peak, here I come..... Let's see if I can get a better time than in June...... Maybe less traffic this time.....Hoping for a decent rental.....
                              • Jeff Schaadt
                                • Jul 2013
                                • 141
                                #150
                                Have some nice pics of Pikes Peak.....will post this weekend. Had the opportunity to make a couple runs Saturday morning....very cloudy in town, once above the clouds, simply beautiful....about the 5th person on the summit.......
