Post your track setup
  • bmwm3n528
    • 3654
    #46
    Engine/Drivetrain:
    Schrick 272
    Mild exhaust porting
    Chip
    Z3 1.9 shift lever
    Suspension:
    H&R Sport springs
    Bilstein Sport struts/shocks
    New OE control arms/bushings
    New OE subframe bushings
    New Lemfoeder Tierods
    JT Design RSMs
    IE Front strut bar
    New wheel bearings
    Wheel/Tire:
    14x6.5" BBS Basketweaves
    195/60 Falken Azenis RT-215
    Brakes:
    ATE Powerslot front rotors(until Spring '06)
    OE blank rear rotors
    Axxis Ultimate front pads
    Axxis Metal Master rear pads
    Flyingbrick DOT SS lines
    ATE Superblue fluid
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    • Dave
      E30 RAT
      • 11675
      #47
      Originally posted by bmwm3n528
      The car behind you in that top pic - do you know whose that is? It looks like a guy from Bluegrass CCA.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • bmwm3n528
        • 3654
        #48
        These guys just recently picked the car up it sounds like. Father/Son.
        It's the one that reads...
        If you are what you eat
        Than I must be an E36 M3
        ...on the back.
        Trevor Ely
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          #49
          trevor finally has a track pic! he is tehcool!
          • bmwm3n528
            • 3654
            #50
            Yeah, it's official.
            Had a good time, definitely hooked. CMP is next.
            Trevor Ely
            • rwh11385
              lance_entities
              • 18403
              #51
              holy shiiiite!
              • rwh11385
                lance_entities
                • 18403
                #52
                stock m42, 'cept for a JC chip
                IE stage 3 springs
                Fresh bilstein sports
                THR cabs
                fresh front end parts
                that's honestly about it. running a recaro shell and 6 pt harnesses, but other than that, nothing too fancy. 16x7 comps shod with 205/50/16 es100's.
                setup is neutral. as my last autox instructor told me (some old guy that drives a JS e30m3, e36m3, blah blah), the car has plenty of grip, just no go. it's a fun car to toss around at a track or autox, and still drive home.
                how do the IE3s compare with the GCs in body roll, ride comfortable, street habits, and auto-x handling?
                kthksbye
                • Dave
                  E30 RAT
                  • 11675
                  #53
                  ...on the back.
                  Used to belong to the Pres of our CCA chapter.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • E30 Racer
                    • Nov 2004
                    • 427
                    #54
                    kthksbye
                    Given the nearly infinite combinations of spring rates available for use with coilovers, and the tremendous effect shock valving can have on ride quality, this is pretty hard question to answer objectively...
                    Garrick
                    1989 325is
                    DSP #72
                    • rwh11385
                      lance_entities
                      • 18403
                      #55
                      fine. i'll just ask Dave when he installs his
                      • Dave
                        E30 RAT
                        • 11675
                        #56
                        Ok. Once they are in, I'll let you know. My rates are different than yours, though.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • rfitz25
                          • 11
                          #57
                          Autocrosser
                          Thanks for all the posts this is helping me out too.
                          Had this car 3 weeks.
                          Ive done one autocross with it, doing another this weekend.
                          Transitioning from SCCA SOlO II DS stock class to Street Touring class
                          Still will be in BMWCAA stock class I think.
                          Stock (after $1500 in work and countless hours in the garage) it runs nice. but too much body roll, too heavy.
                          87 325is
                          Mostly stock.
                          new front brake hoses (not stainless :( )
                          new rear shock mounts (OEM)
                          K&N filter and intake arrives tomorrow (bavarian autosports)
                          nice steel heat sheild next week. (signaturemotoring.com)
                          Bilstein sports go on Thursday
                          OEM adjustable camber front shock mounts as well
                          with Suspention Techniques springs, should lower 1.3"
                          14x6.5 BMW/BBS rims repainted with polished lips
                          Dunlop 205/60R14's OK for now, thinking about es100 yokohamas??
                          I'll let you know how it goes.
                          8-)
                          Cheers,
                          Richard
                          [/SIGPIC]--------------------
                          '87 325is Delphin Metalic
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            #58
                            87 325is
                            Mostly stock.
                            Cheers,
                            Richard
                            OEM adj camber mounts?.......come again?...what are those?.....
                            • Jase007
                              • Dec 2004
                              • 5
                              #59
                              Perhaps he means reversable upper strut OEM crash mounts that can add or subtract ~ 1.2 degree camber depending on how rotated.
                              if not .. I have no idea ...
                              Jase
                              Jason
                              '90 325ix ~ '89 325iX ~ '00 E39 528iT 5M
                              JScottRacing
                              • Jase007
                                • Dec 2004
                                • 5
                                #60
                                Have only tracked my iX a few times [$$ goes to other track car ;)] but:
                                Intalled:
                                H&R sport springs
                                Koni sports SA
                                IE adj. 19mm rear bar
                                IE R sway body mounts
                                [custom reinforced tabs on TAs]
                                SS lines / superblue / track & street pads depending
                                [custom F brake air ducting]
                                OE 15X7 BBS baskets.
                                GC RSMs
                                K-mac adj. toe / camber eccentrics for TA
                                Powerflex R subframe mounts
                                Powerflex CAB centered.
                                Jason
                                JScottRacing
