Post your track setup
  • rfitz25
    • 11
    #61
    rotating offset shock mount
    Yes thats them.
    There supposed to be acceptable in the stock class as an OEM replacement.
    Offset hole.
    They just rotate to the desired offset.
    I got the intake in last night.
    Sounds good.
    Feels like a little better throttle response.
    I'm getting the shocks springs installed tomorrow morning.
    Still not sure the Suspension Tecniques springs are the right choice.
    Any suggestions??
    Any Reasons why I should get the Eiback Pro-Kit intead???
    Cheers,
    RIchard
    87 325is
    [/SIGPIC]--------------------
    '87 325is Delphin Metalic
      • 34847
      #62
      M3 bushings work great on an ix.. CV joint wear is overatted. I have 40,000+ miles and no problems..
      • Smoove1
        • 505
        #63
        Originally posted by e30sd
        setup is neutral. as my last autox instructor told me (some old guy that drives a JS e30m3, e36m3, blah blah), the car has plenty of grip, just no go. it's a fun car to toss around at a track or autox, and still drive home.
        I actually work for that old guy. He's been letting me Auto-x the J-stock E30 M3. you've probably seen it before:
        Dinan J-stock suspension
        8 point weld in cage
        15x7 basketweaves w/ Toyo RA1s
        Simpson 5 point harnesses
        Sparco steering wheel w/ quick release.
        This is by far the best handling car I have ever driven... just lacks power. It's for sale BTW.
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          #64
          dude dale of course. i just didnt wanna be a snob and say dale. best times is when he brings the 540i.
          • Smoove1
            • 505
            #65
            Speaking of the 540, I talked him into doing a drift contest at willowsprings on the 20th. The suspension setup will be rear sways on the stiffest setting, front loose, 235/40r17 cheap ass tires in the rear, 255/40r17 Toyo RA1s up front. The best mod is the 62 year old senior citizen behind the wheel. Those drift kids should be in for a rude awakening.
            • e30sd
              Fistee
              • Jan 2004
              • 5517
              #66
              damnit i'm doing a buttonwillow on 5/20. weak.
              • Ball325
                • Sep 2004
                • 187
                #67
                E30 M3 prepared to the limit of the JP rule book for BMW Club racing. if your allowed to do it we did it.
                Suspension and such Koni Double Adjustables all around and GC adjustable spring perches, Delrin and urethane bushings and mounts all around. Custom cage, AIM Sports Mychron3 XG LOG Data Acquisition, Hoosiers, OEM Brakes,
                • jht3
                  • 288
                  #68
                  88 M3
                  eibach springs (don't know which)
                  bilstein sports
                  stock strut hats
                  offset control arm bushings
                  eibach anti-roll bars
                  stock 15x7 wheels wrapped in 225/50 T1-R's (RA-1's coming soon)
                  RRT 19mm wheel studs
                  RRT brake cooling kit
                  RRT rear shock mount reinforcements
                  brake pads that came on the car (pagid somethings maybe?)l
                  Recaro SRD seat on sliders at lowest setting, mounted on low wedge bracket
                  Momo Competition 350mm wheel with Smart Racing spacer
                  Lowes clutch stop kit
                  feels balanced and neutral on the track. fetches groceries just as well
                  James
                  '88 M3
                  • Gus
                    • Jan 2004
                    • 285
                    #69
                    1988 325i Motorsport
                    H&R Sports
                    Bilstein Sports
                    Front RD Strut brace
                    rear strut brace
                    stock ms rear sway (14.5mm) stock front
                    3.64LSD
                    powerflex urethane CAB's, subframe bushes
                    Ireland urethane engine/box mounts
                    Momo Corse wheel
                    Dunlop Direzza DZ101 205/55R15 on 15" weaves
                    Brakes: stock with stainless lines
                    good setup for street, ok for track. understeers mildly at high speeds (as someone mentioned, esses especially). provides easy to control 4wheel drift if you steer super sharp (yes on purpose)
                    what i would change: decent brakes...something to fit under the 15's (have 2 sets, will put race rubber on sometime. full slick maybe but would need to baffle sump/fuel tank) 280-300mm disc with wilwood superlites, but $$
                    front camber plates to help dial out some understeer: supposed to be on order from IE, but have not shipped in about 2 months
                    if i was going more hardcore track, would prob go the j stocks, i really like em in a friends race car. unsure if i would add the STsways
                    roll cages are great, but to keep one practical you dont gain the full benefit of tying to strut towers. front strut brace is mint, rear doesnt do bugger all.
                    would also look into a faster rack, e30 one is SLLOOOWW. like the z4 one though.
                    in the nearer future may do m3 diff bushing/urethane trailing arm bushes
                    but im done for the moment with cars...engine swaps frustrate me right now!
                    Edit: run some cheap (Jamex) bucket seats for track, black leather sports otherwise.
                    also have an e28 23.X??mm master cylinder. reduce pedal travel a wee bit and make heel toeing better. have ABS
                    JUNGL3
                    1990 "333i" Sport
                    • Low Level E30
                      • 1646
                      #70
                      Tell us more about your car, Gus --- specifically interested to hear more about how it performs on track days.
                      Also - are you happy w/ your rear sway bar? I'm debating whether or not I want a big front and small rear, or bigger at front and rear.
                      Thanks!
                      • Gus
                        • Jan 2004
                        • 285
                        #71
                        Thanks!
                        Well, it doesnt work right now! getting some wiring sorted then back into the fray.
                        its ok on track days....like all e30's too slow, but i like it...if i was really wanting to improve it would want to get rid of some understeer, and put some track rubber on my spare set of baskets, and do brakes..but you can see where im getting at, never ending! ideally would sr20det it to lose the weight up front first and work around that
                        def like the rear sway...very noticeable swapping between the two...not a big fan on too stiff rear sways though...on a friends race car it lights up inside wheel to much on tightish corners (ST sways)
                        JUNGL3
                        1990 "333i" Sport
                        • OSAH racing
                          • Apr 2022
                          • 244
                          #72
                          90' 325i in progress for several years.
                          Stock M20 bottom end with 90K, Bearings done 1k back,
                          Baffled pan
                          Rebuilt head, Bimmerheds 274,
                          Turner chip
                          Racing Dynamics headers, 2 1/2" SS borla exhaust
                          M3 rack
                          3.73 LSD, DSSR rebuilt shifter
                          OFCA
                          IE adjustable camber plates
                          Condor rear adjustable TA bushings
                          OEM bushings at the engine, trans and differential
                          Poly everywhere else
                          Koni sport SA
                          HR sport
                          Hawk track pads, SS lines
                          Spec e30 front sway, stock IS rear
