Post your track setup
  • Charlie
    kid tested, administrator approved
    • 6686
    #31
    I meant to type "oversteer", sorry.
    Yea, the rear was twitchier with the rear bar on full stiff, but initial turn in still plowed like a pig. After I put the camber plates in, the turn in was much nicer, and I went down to a softer setting on the rear bar, definetly made the car more driveable.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • JRKOUPE
      • Dec 2004
      • 3159
      #32
      [QUOTE=Charlie]So, um, you mean like what we're running?
      Mostly stock motored M20 325is. Turner J stock springs with the custom valved bilsteins, RRT -2 degree fixed camber plates, suspension techniques swaybars on 205 RA1s on 14 inch basketweaves. Stock rotors, SS lines with Hawk blues, HP+'s & HPS's for pads.
      Corbeau Forza seat, VSR rollbar, Canon Zr100 DV camera on the ioport rollbar camera mount. Rare european rubber chicken mod.
      hey charlie ...pm me on your zr 100 please.I want to do this.
      • JRKOUPE
        • Dec 2004
        • 3159
        #33
        track set up......
        90 325 i
        HR race springs
        Koni top adjust SA's
        GC RSM's
        RRT max camber plts we/ oe strut bearings.....neg 3.2 camber up frt
        Powerflex offset poly CA bushings
        IE poly subframe(street) and RTAB
        Kosei 15/7 wheels
        toyo RA1 225/50's
        AP roll bar/IO port cam mount
        Fire bottle
        Sparco driver and Corbeau pass fiberglass shells
        5 pt harnesses on both
        2.5" single exhaust w/ hi flow cat and borla can
        Suede personal non airbag 3 spoke wheel
        TMS(Precise Fit) ss lines
        Cobalt xp 9 pads up frt w/ oe rotrs
        Axxis ultimate rears w/ oe rotors
        Mark D 93 oct chip
        Car feels very planted and stable. If anything she has very mild understeer on slow/medium tight radius corners. Never felt any twitch in rear.
        • E30 Racer
          • Nov 2004
          • 427
          #34
          Originally posted by Mystikal
          Pic for fun:
          No helmets??? Not a smart move in an E30...
          Garrick
          1989 325is
          DSP #72
          • redcarbon
            • Apr 2005
            • 213
            #35
            I don't have too much experience, I have done half a dozen autocrosses in my car, all but one was with this setup minus the anti-rolls and one autocross (just today) with this complete setup:
            1991 318is
            K&N filter
            MarkD Chip
            Dynomax Muffler
            IE stage III Springs
            GC Koni SA - top adjustable
            M3 offset CABs
            IE Urethane rear subframe bushing (street)
            IE Urethane TA bushings (street)
            new tie rods, control arms
            new OEM strut bearing mounts
            IE Big Sways with reinforced rear trailing arm tab
            (front medium setting, rear fairly soft)
            16x7 SSR Comp wheels with 205/50-16 Hankook RS-2s
            4.10 small case LSD
            JB Racing Aluminum Flywheel
            The car has slight understeer from what I can tell, I haven't had it at the maximum limit much. It tranistions well, but I hate how slow the steering is and I have some friction in my front anti-roll that causes it to stick and preload the tire that was last laden (so my car pulls slightly right after hard right turns because the anti-roll can't completely unload). I searched for some lubricants, but all I could find was some spray lubricant. Any suggestions for a lubricant suitable for urethane bushings? Thanks. I hope to hit a track day soon and then I can better judge the cars balance.
            318is -gone-
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #36
              Welcome to Trillium chapter auto-x. All low-speed technical courses, you'll never come out of 2nd for the entire session. Maybe 1 guy will wear a helmet out of the entire group.
              • postmaster
                • 93
                #37
                '95 M3
                Engine:
                Intake
                Full SuperSprint Exahust
                Jimmy C chip
                Suspension:
                GC Race Koni Setup (550/650)
                GC RTAB Shims
                RD Sways
                LTW Front Strut Bar
                X-Brace
                Kosei K1 17x8.5
                255/40/17 Kumho MXs
                Brakes:
                Euro Rotors
                SS Brake Lines
                Solid Brake Guide Pins
                Real Brake Ducts
                Interior:
                Custom 4-point roll bar
                Sparco Rev Seats
                Sparco cam lock harnesses
                Momo Competition Wheel
                • Bavarian3
                  • 1230
                  #38
                  Post,
                  My brother has a 95 Avus with Gruppe N spec Bils and HR Race springs. How do you like your setup? 255 fit without any rubbing?
                  • arthurc
                    • Nov 2005
                    • 10
                    #39
                    The setup is optimized for SCCA Solo2 G-stock class competition:
                    1991 318is
                    IE 25mm adjustable hollow front sway bar
                    BMW 0.5 degree offset strut mounts
                    New tie rods, control arms, steering rack
                    14x6.5 basketweaves
                    205/55R14 Hoosier R3S03
                    4.10 LSD
                    SS brake lines
                    I've only had one event with it so far and yes - the slow steering is not the best thing. Other than that, very happy with my first RWD race car.
                    redcarbon - my car is very similar to yours! There's a special super-sticky grease for bushings. Just search for "bushing grease".
                    • e30Matt
                      • 5077
                      #40
                      She hasn't been to the track yet, will be seeing a lot of VIR/RoadAtlanta this spring/summer though. I hope to run the full autocross season as well... hopefully this thing will hold a candle to my old 318's handling, only with a little less understeer.
                      1987 325is
                      ST 22mm/19mm adjustable sways
                      IE Stage 3 springs
                      Koni SAs (have yet to adjust them for track use, will post adjustments when I do)
                      JTD billet RSMs
                      Urethane trailing arm/subframe bushings
                      Treehouse Racing CABs
                      IE front strut brace
                      Bottlecaps w/195/60 Falken Azenis RT215
                        • 34839
                        #41
                        bottlecaps are only 14x6.. :P
                        • Low Level E30
                          • 1646
                          #42
                          How do you like your Treehouse Racing CABs, Matt??
                          Are they harsh on the street?
                          • e30Matt
                            • 5077
                            #43
                            A little more NHV, but it's worth it. Turn-in is sharp and steering inputs are very, VERY accurate and responsive. Definitely recommend them.
                            • e30Matt
                              • 5077
                              #44
                              Woopsy. :-D
                              • Jon325i
                                • 6934
                                #45
                                My track gear...
                                Shocks: custom-valved B-Sports
                                Springs: IE Stage 3s
                                Sways: stock (IE adj. 25F/22R to be installed Spring '06)
                                Worn-out OEM rear subframe bushings
                                Ground Control RSMs
                                Chassis: IE front strut bar
                                Wheel/tire: Bottlecaps with Azenis Sports (195/60s)
                                Rotors (front): Warped Ate PowerDiscs, rotors (rear) OEM
                                Pads (front): CarboTech XP8s, pads (rear) AutoZone crap specials
                                Brake lines: OEM rubber
                                Brake fluid: Motul RPF 600
                                Engine/drivetrain: JC chip, Stromung cat-back, 4.10LSD, and UUC Evo3 SSK
                                Behold the bodyroll goodness....
                                Jon
                                Rides...
                                1991 325i - sold :(
                                2004 2WD Frontier King Cab
                                RIP #17 Jules Bianchi
