Post your track setup
    Insert here.
    Originally posted by Bavarian3
    Insert here.
    that's what she said
      Don't ruin this awesome track forum...
        So, um, you mean like what we're running?
        Mostly stock motored M20 325is. Turner J stock springs with the custom valved bilsteins, RRT -2 degree fixed camber plates, suspension techniques swaybars on 205 RA1s on 14 inch basketweaves. Stock rotors, SS lines with Hawk blues, HP+'s & HPS's for pads.
        Corbeau Forza seat, VSR rollbar, Canon Zr100 DV camera on the ioport rollbar camera mount. Rare european rubber chicken mod.
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
          --Stock m42 318iS
          Koni SAs
          e30m3 suspension components
          600#Front 650#Rear ERS springs
          GC adjustable camber/caster plates
          Stock Front Sway
          Rear Sway delete
          15 x 7 wheels
          205-50-15 Falken Azenis 615
          SS lines
          Hawk HPS pads
          Stock Rotors
          ATE Super Blue
          Last alignment readout(measured with 17" wheels with 215-40-17 tires @ 17 x 8 Front ET 15, 17x9 Rear ET 20)
          Front End- Left || Right
          Camber -3.4 || -3.8
          Caster 9.4 || 9.6
          Toe -0.01 || 0.00
          Rear End- Left || Right
          Camber -2.4 ||-2.4
          Toe 0.21 || 0.14
          Overall eval: Car's balanced. Doesn't understeer, rear end isn't twitchy. Very satisfied after visting little taladega for about 6 hours of track time. Front end has a lot of "Stick" Rear end behavior is not sloppy and neither snappy nor senile. When I start auto-xing in March I will post more updates.
            Interesting guys.. if you could, post various experience, like understeers in low speed corners, well balanced and if you would change anything? Lets get a good track topic going...
            Heres mine:
            88 M3 with Bilstein sports (not revavled) with Grupp N springs (Eibach), stock sways, Sparco strut bar, SBI rear bar. Stock strut mounts and no camber plates. Running around -2.99 in the rear and -2.5 in the front. 225/45/15 Hoosiers. No understeer or oversteer. Very balanced through the corners but might need a bit less roll.
            Interesting (but stupid how this came about) I ran Victoracers 205/50/15 in the rear and 225/50/15 in the front. I totally forgot that we were running a 15x7 and 15x8 Kosei at the time. The car did not produce understeer but a bit of oversteer. I ran this for about four sessions (30 minutes)...
            I finally ran Hoosiers at low pressures (which I've normally ran high, around 36 or so) and it hooked up great.
              aint a "track car" but i took it to the track
              basic modded m20 (chip intake exhaust) blah blah, its stock.
              4.10 60% 3 clutch rebuilt diff
              fk suspension
              m3 rear sway with poly bushings
              zimmerman x-drilled all around
              hawk hps
              ate superblue
              17x7.5 kopis with 215/40/17 es100's.
              very fucking fun set up on the track. couldnt have asked for more although i would have loved a little better tire, and possibly some brake cooling (the glen was tough on my brakes)
              Dan
                Did you have any over/understeer? Would you change anything other than the tires or wheel size?
                  my setup sucks. the rear lets go before the front because i have no camber back there. and my ghetto solution of no rear bar is the weaksauce
                  i need to drop the rear an inch and rehook my bar back there. possibly throw down for an IE big front bar, then swap rear rates if need be.
                  my more advanced auto-x friend called it neutral, and coming from a FWD car himself, that means "understeer", LOL. but on track it seems good
                  alpine cd and infinity stereo system in my "track car"
                  cold a/c
                  plush seats and leather rear seat
                  streetable rates, and comfy ride if on 205/55-15s
                  noisy rear (RTRS subframe mounts)
                  IE engine mounts and BW tranny, z3 2.8 SSK
                  GC 300/475, koni SAs, stock sway in front, GC RSMs, RTRS trailing arm eccentric bushings, m coupe diff bushing, GC camber plates
                  205-50-15 Azenis RT-215 on 15x7 ET17 koseis....
                  ss lines, stock rotors (may throw in ATE Powerdiscs for the hell of it, $30 used ha), HP+ noisy bitches in front, Axxiss Ultimates in back.
                    the over/understeer was pretty neutral with this set up, but i definately wouldnt change the wheel size, the handling characteristics with the smaller sidewall were awesome. i would just want a stickier tire with better wear, my tires were pretty much garbage after a couple autoX's and the weekend at the glen.
                    Dan
                      Mine is balanced enough for now, but I have camber plates on the way to help with tire wear. M3 rack helps a huge amount on autox course, but not as much on tracks (haven't been on one so far with a tight 180).
                      S50 - intake, exhaust, chip
                      3.23 Torsen LSD
                      Bilsteins with H&R Race
                      Sparco front bar, custom rear bar
                      e36 M3 steering rack
                      225/50-14 hoosiers r3s04 (track) and a3s04 (autox)
                      IE rear subframe mounts
                        318iS w/ M52 2.8L
                        E30 M3 brakes and suspension
                        4.10 LSD M3 diff (Getrag 260)
                        GC 350F 475R
                        Custom valved Bilstein Sports
                        GC front sway endlinks
                        Treehouse CABs
                        Urethane rear subframe bushings
                        Front stock sway (20mm) attached to M3 strut link
                        Rear stock bar (12mm)
                        225/45R16 RS2s (formerly T1S) on 7.5" rim
                        Superblue fluid
                        Axxis ultimates front and rear
                        eccentric RTABs (set to max pos, min toe in)
                        Motorforce camber plates (formerly SBI)
                        Last alignment:
                        camber: -2.5 deg front
                        -2.0 deg rear
                        toe (IIRC): 0 deg front
                        (forgot rear)
                        When I initially did the 5 lug swap (w/ M42), I kept the front and rear bars in the stock positions while running the GC spring kit. The car had quite a bit of oversteer, both track and autox, and a bit too much lean. Repositioned the front bar and killed a large portion of the lean, but created quite a bit of exit understeer at the track (fairly neutral in a slippery parking lot).
                        The 24v swap lessened my track exit understeer a bit by putting more weight up in the front, but it still has a bit of push. Overall a decent and beginner friendly setup, but I think I'll dial in a bit more front camber for my next DE.
                        San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
                          Stock M20
                          Stock Brakes w SS lines - OE Blank rotors, HP+ all around
                          3.73 LSD diff
                          GC Adjustables
                          Koni SAs
                          Treehouse CABs
                          Urethane rear subframe bushings and CA bushings
                          Front Cabrio stock sway
                          Rear stock bar
                          195/60-14 Azenis RT-215 on Steelies
                          IE camber plates
                          Cant comment on it yet, as it is not completely installed. First auto-x event is 3/12 - I'll know better then.
                          Inside - no cage, grey cloth sport seats, CG Lock, no rubber chicken.
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
                            Stock M20
                            IE Stg III's
                            Koni Yellows
                            IE Urethane TA and SF bushings
                            M3 CAB's
                            Stock Sways
                            Stock Pads (first time I went out)
                            205/60R14 Ziex's
                            - very slight understeer at high speeds (a good thing IMHO)
                            - low speed understeer (unless I overpower it with throttle)
                            - not so good turn it, can be attributed to tires
                            - a bit too much body roll, need to get new (or solid) end links, mine are not so good, hopefully it fixes part of the problem
                            Keep it slideways!!
                              it's hard to compare my car, and I've only done autox so far, but here it is anyway:
                              somewhat stock M20
                              springs: ix H&R sports
                              shocks: koni SA
                              sways: stock (17/14.5)
                              front adjustable swaybar links
                              SS brake lines
                              poly rear subframe and trailing arm bushings
                              M3 offset CABs
                              front strut bar
                              falken azenis RT215 195/60-14
                              otherwise my car is 100% stock, no removed AC, no stripped interior, no gutted insulation or trunk tar. and it's staying that way. ;)
                              Understeer isn't really much of a problem, I'd describe my car overall as neutral (of course there is a natural understeer tendancy from AWD). Definitely much improved over a stock ix. I don't think my suspensions stiffness is much of an issue, but body roll is a bit too much. As long as I'm careful with the throttle (and AWD requires care), I can control the amount of understeer and even oversteer in the right situations. I've never once experienced high speed understeer.
                              I haven't really changed much in the last 3 years, but that's okay because I've had time to improve my driving instead. But the weakness are starting to show:
                              auto tranny (sometimes I need to shift down, but I just can't)
                              sways: worn bushings and just too much dive (I want an 18mm front and 18/19mm adjustable rear)
                              front camber, I just don't have nearly enough (1.5 degrees at the most)
                              rear toe/camber settings, I have no idea what they are, it's very unlikely that they are optimal.
                              I plan on taking care of all these issues this spring, I'd like another degree or so of negative camber up front, get adjustments for rear toe/camber and have a real alignment done, and replace my worn swaybar bushings/upgrade rear bar. I'd also like wider tires, but I'm still waiting for RT615s in 225/50-15 or 225/45-16 to come out.
                              while we're here, anyone have an idea of the ideal rear toe/camber settings for an E30?
