Brake Cooling Hose Routing
  • Beej '86 325es
    • 2639
    Side note, not brake related: what material is your splitter made from?
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • vpilarrt
      • Jun 2006
      • 2096
      1/8" Lexan - I'm pretty sure. I found it in a trash can at VIR, it was from a E36 and I cut it down to fit.
      • Beej '86 325es
        • 2639
        I finished my brake ducts today, so that I can give them a trial run with the Lotus guys next weekend.
        This is going to be photo heavy...
        The Condor plates are nice, but my Massive BBK required the upper brake backing plate hole to be cut off. Plus, the diameter of the rotor is larger, so it needs to be reoriented to get the air in the right spot.
        I had the plates powder coated.
        Then I fabricated some adapter Z-angle brackets that pick up the caliper mounting bolt.
        I used the Garagistic duct adapters for the front valance and just silicone glued them on really well. Pretty straight forward, not worth the pictures.
        For the forward-most clamp on the driver's side, I used a 3" adel clamp using an existing stud on the frame. The passenger side did not have the stud, so I looped a zip-tie through the frame, then one around the duct.
        For the second attachment on both sides, I used another 3" adel clamp, but bent the tabs to make it clamp more symmetrically (hard to explain) and attached using the existing threaded studs on the insides of the wheel wells.
        The third attachment is the tricky one. I used a zip-tie around the tie rod. This is the most important one. The movement of the duct is all between the second and third clamp. As you turn the wheel from lock-to-lock, you'll have to determine how much slack to allow. The duct will rub on the tie rod, so I zip tied some heater hose on it. It will also want to rub on the edge of the subframe, and you'll have to rotate the duct a little bit forward on the tie rod in order to avoid this.
        Lastly, I found some 3" hose clamps to attach the duct at the brake ducts.
        Top view:
        Wheels straight:
        Wheels turned out:
        Wheel turned in:
        -Brandon
        '86 325es S50
        For sale:
        • Digitalwave
          is a poseur
          • 6292
          Looks good, thanks for the info!
          What is the fuel tubing on your tie rods for?
          RISING EDGE
          • Beej '86 325es
            • 2639
            Thanks! It's just some heater hose I zip-tied in place. When I turned the wheel, the hose was dragging on the jamb nut on the tie rod. Problem solved!
            -Brandon
            '86 325es S50
            For sale:
            • rwh11385
              lance_entities
              • 18403
              Nice. Jordan (gearheadE30) doesn't frequent R3V anymore but has brake cooling plates on his kitchen table so I'll share this with him.
              Have fun at the track day - I'd enjoy coming out to see Evora do work but we'll be in Joliet. I can't wait until the 400 comes out and get to hear it in person.
              • Beej '86 325es
                • 2639
                Are you guys "Doing Time" this weekend?! [emoji3]
                The Evora 400 is sick. The guys let me drive that thing...only two in the US; both European spec to get US interest. The sound is just insane.
                -Brandon
                '86 325es S50
                For sale:
