Relocating lightweight battery track use
  • Digitalwave
    is a poseur
    • 6299
    While every pound counts, 6.5lbs in the grand scheme of the car isn't very much. You are also taking the cable and battery from one of the lowest points of the car and placing the battery a few feet higher on the battery shelf in the bay. Probably best to go to a lighter battery but keep it in the stock location.
    RISING EDGE
    • TobyB
      • 5296
      removing weight no matter where will make you faster.
      After 15 years of racing, I do stand by this.
      Yes, you'd better be buff, slender, and have drilled lightening holes in everything you
      can get to, including your butt,
      but less weight in a sedan= lower lap times.
      t
      • e30s50dan
        • Nov 2008
        • 2076
        My battery box is completely removed from the rust. I will have to make a battery box out of aluminum to keep it in the rear. The pc680 weights 13.2 pounds..
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • JimmyP
          • 394
          A solid choice backed up by decades of precedent.
          Your corner weights will thank you.
          Jimmy P.
          87 E30 M3 Prodrive British Touring Car
          88 E30 M3 Zinnoberot - Garage Queen
          88 E30 M3 Lachsilber - SCCA SPU #98
          92 M Technic Cabrio - S14 Powered!
          98 318Ti Morea Green
          04 Ford F350 Dually Tow Machine
