E30 1/4 mile times
  • alistairolsen
    • Jul 2017
    • 191
    E30 1/4 mile times
    I'm curious what quarter mile times people are running with E30s. Could those who have run theirs up the strip share times?
    Can we keep posts to this format:
    Engine: M42
    Power: 140bhp
    Weight/description: Full road trim Coupe, estimated 2700lbs
    Tyre make and size: Toyo R888 205/50 R15
    60ft time: 2.1s
    1/4 time: 15.5s
    Speed: 95mph
    Notes: (such as "drag car converted to live axle and tubbed")
    And only post times you've run please, not "my mates uncles dog ran a 9 flat in his 318"
    Thanks!
  • 2mAn
    Señior Mod
    • 20906
    your 60ft time could use an improvement, especially with R888 tires. Launch that little 4banger
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • alistairolsen
      • Jul 2017
      • 191
      Oh that's just some example numbers to illustrate the point!
      • JGood
        • Jan 2004
        • 7959
        I've been to the track a bunch of times in my e30's over the past 16 years with various engines in them haha. None of them are drag cars by any means, but I have a track a few miles away, and it's cheap to run.
        Engine: m60b44
        Power: ~300whp/300wtq
        Weight/description: 2,800lb, full street car, getrag 420g w/ 3.25LSD
        Tyre make and size: 235/40/17 Sumitumo HTRZ-II
        60ft time: 2.0
        1/4 time: 13.1
        Speed: 108mph
        Engine: m50b25tu
        Power: 188whp
        Weight/description: 2,800lb, full street car, s50 cams and chip, 3.73 LSD
        Tyre make and size: 205/50/15 Hankook Z214 r-comp
        60ft time: 1.9
        1/4 time: 14.4
        Speed: 96mph
        Engine: m20b25
        Power: 145whp
        Weight/description: 2,400lb, gutted track car, Dinan chip
        Tyre make and size: 225/50/15 Kumho V710 r-comps
        60ft time: 1.9
        1/4 time: 14.6
        Speed: 92mph
        Engine: m20b25
        Power: 145whp
        Weight/description: 2,800lb, Dinan chip
        60ft time: 1.9
        1/4 time: 15.4
        Speed: I forget, I think ~90mph
        Engine: m20b27
        Power: ~100whp
        Weight/description: 2,800lb, chip, 3.25 LSD
        Tyre make and size: 205/50/16 performance street tires of some sort
        60ft time: 2.1
        1/4 time: 16.3
        Speed: I forget, I think ~87mph
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • Nisse Järnet
          • Aug 2013
          • 1221
          Engine: M50
          Power: 7-800hp at this run, now more..
          Weight/description: Full road trim sedan, 2866lbs / 1300kg with full fuel tank but no driver.
          Tyre make and size: Nankang NS-20, 215/45-17
          60ft time: 1,80
          1/8 time: 6.88
          1/8 speed: 112mph / 181kmh
          1/4 time: 10.3
          Speed: 143mph / 230kmh
          Notes: 4wd
          Can do alot better..
          E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
          E30 M50 6 spd 764whp @ 24psi.
          E30 M20 6 spd 675whp.
          • e30s50dan
            • Nov 2008
            • 2076
            ^^^ damn good
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • Kershaw
              • 11822
              My first e30 ever was a tired 325i POS. Took it to the drag strip once and ran 15.9.
              AWD > RWD
              • Karolis
                • Aug 2015
                • 27
                Engine: M42B18 from e36
                Power: 140bhp (103kw)
                Weight/description: Full road trim Coupe, with lpg system, so more weight than standard
                Tyre make and size: simple yokohama 195 50 15
                60ft time: [must check, will update]
                1/4 time: 16.9-17.1s
                Speed: [must check, will update]
                Notes: basic european 316i with engine swapped from e36, M42B18, lpg system, lose about 0,2-0,3 seconds on lpg. Draging on road flat surface, lsd with 4,45 ratio, e30 316i gearbox. Drag times measure with Racechrono and 5hz qstarz external antenna, good precision but a 0,1 must be always considered like possible error. Car seems slow.
