Anti-surge tanks are indeed for two-stage fuel systems only. Not working for single stage pumps. The lift pump fills the anti-surge tank (swirl pot) which remains full at all time (excess fuel returns back to the tank). The swirl pot is also fed by the fuel return from the fuel rail. The system ensures constant fuel supply to the main pump. Even on the longest sweepers.
Fuel Accumulator - OEM Ford Option
massivebrakes.com
Originally posted by djjerme View PostIs that on M20?
Last 14hr race we did on my car, M20 stock except for cam/injectors/chip, was getting 1:30 per stint at the Ridge. And while we could only dump 10 gallons (almost 12 with our bumped out cans) we never had starvation issues. Even with an extended yellow and going a couple 1:45 stints.
Sent from my SM-G930V using Tapatalk
Yes m20. We typically dump 15gal per driver change. We modified the fill necks so we can use a 1" hose on a jerry rig style can with a big 3/4" vent hose. Takes 1.5min per fill up.
Originally posted by slums View PostI did a quick 3D print design and printed out a proof of concept piece using a nylon filament.
Unfortunately the nylon dissolves in gas (tested it over a few days), and I don't have access to any more "hardcore" filaments with this particular printer.
There was also the question of having to find a way to epoxy some brass fittings etc.
Meanwhile I ordered the Ford unit, so more to follow when I receive it!
IG @turbovarg
'91 318is, M20 turbo
[CoTM: 4-18]
'94 525iT slicktop, M50B30 + S362SX-E, 600WHP DD or bust - updated 3-17
