I have reviewed the SCCA Solo 2 '07 rule book and some other sources and just cant place the car. I am pretty sure I can run DSP but would like to know if I could run STS or STX? I cant tell... Here are the details, hopefully you can help. I would like to order the magentic numbers before my first event.
Car spec
'88 BMW 325is 2.5l 6cyl 2 door 4 seat with factory limited slip diff, factory wheels
Aftermarket, non OEM: frnt & rear sway bars, shocks, springs, bushings, braided brake lines, cone air filter, catback exhaust, camber plates, strut bars, after market wheel studs, ECU chip
I believe the car could run DSP, but I would like to know if it could run in the street tire class since I do not have the budget this yr to run R DOT tires.
Car spec
