Solo 2 Classification Help
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
As a novice, you're not likely to be competing for trophies anyway, and the smaller wheel definitely makes it easier to steer quickly (my airbag wheel is in the garage somewhere)
I'd say run whichever one has more people in it since that will give you more of an idea of where you stand.Comment
Kind of right. You forgot the ST classes, which are meant to fall between Stock and SP. Many of the front runner SP cars are trailered to events and not street legal any more. SP rules allow modifications which make cars highly unliveable for the street.
The set of classes really is:
Stock (A,B,C,D,E,F,G,H)
ST (S,S2,X,U)
SP (A,B,C,D,E,F)
SM/SM2
Prepared (X,B,C,D,E,F,G)
Modified (A,B,C,D,E,F)
It's kind of hard to say you progress directly from one to another--an E36 M3 will run BS, BSP, FP. A 318is runs GS,DSP. 325e/i runs DS,DSP.
I don't remember the Prepared and Modified classings off the top of my head. ST and SM have a different set of rules such that you really would need to check the rulebook to figure out exactly where they run. MOST 325s will run in STX.
The key to remember with the rule book: If it doesn't say that you CAN change something or run something, then you can't.
Not to beat the dead horse, but just to clarify. The early 318i's (SOHC, not DOHC 318s) are to run in FSP/FP and not DSP is that correct ?
Also, when does one decide to run in OSP ?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Also, when does one decide to run in OSP ?Comment
