Solo 2 Classification Help
  • Jean
    • 18228
    #31
    "83-85 318i M10 (8v) goes HS, FSP, SM"
    Would it also then goto FP ?
    • kishg
      • Sep 2006
      • 2624
      #32
      i must admit these class designation confuse me. is there a concise explanation of the different classes without reading through the rulebook? What class would my car be in:
      '91 325i with Sport package
      Ground Control Coilovers with Koni SA FSD dampers
      GC camber plates
      Treehouse CABs
      stock sways
      stock LSD, transmission etc.
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • hoyabmw
        • Dec 2006
        • 207
        #33
        GC camber plates
        Treehouse CABs
        stock sways
        STX with street tires, DSP with R-Comps.
        If you have changed the steering wheel and gotten rid of the airbag, you can't run STX.
        Yes, I am the timing chief for the local region, and run a DSP 325i.
        • JGood
          • Jan 2004
          • 7959
          #34
          He can run STS if it's not a LSD. The only thing that would put it in STX is the clutch-type LSD if it is equipped with that.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • JGood
            • Jan 2004
            • 7959
            #35
            It's a simple concept overall. Basically, the letters A-H are standard for each class. They separate cars by performance, which varies by the actual class level (see next sentence). So then you have stock (S), street prepared (SP), prepared (P), and modified (M). All of these classes utilize r-comps (not required, but recommended), and to understand them, you basically have to read the rulebook. If you don't want r-comps, you could go into a street touring class (STS, STX) and run with other people with street tires (you'll probably get killed by WRX's and the like). Then there is SM, a class which has "loose" rules made to allow cars that don't fit into the other ones nicely.
            That's my very basic understanding of the system anyway. Someone correct me if I'm wrong.
            • kishg
              • Sep 2006
              • 2624
              #36
              thanks. that clears things up somewhat. to clarify a bit further, i am running street tires, none airbag wheel on airbag car and lsd. rather a mixed bag :) does that dump me into SM? oh and btw, i've never run autox before. does driver skill (or lack of it) even come into play for the class or just the car?
              '91 SpecE30 #523
              128290
              • JGood
                • Jan 2004
                • 7959
                #37
                It's 90% skill and 10% car.
                You will probably finish in last place, unless there is another novice in your class. don't be a hero, just learn how to drive, and you'll have a blast.
                I have no idea about your steering wheel, though.
                • iNetMANN
                  • 45
                  #38
                  SM gets real complicated once you start reading the minimum weight to displacment and multiplier for boost...
                  What that comes down to is my 318i is the minimum weight (2200Lbs) for a 2.1L car without boost. Once you add boost there is a 1.4 multiplier involved to calculate displacement etc, then minimum weight increase as displacement increases... SM involves the most research and the rules will probably change again in the near future.
                  What it all comes down to is there is nothing like reading the manual because then you'll start figuring out what questions to ask, where you wanna take your car class wise, and if it's really worth all the trouble (it is).
                  Welcome to the world of SCCA Solo2,
                  RODD
                  2008 SCCA National Tour - Packwood, WA.
                  www.M10Racer.com
                  '4-banger 8v Racing'
                  • Jean
                    • 18228
                    #39
                    So then you have stock (S), street prepared (SP), modified (M), and prepared (P). SM can still be a street legal car, and SM doesn't allow removing all of interior. Prepared car can be all gutted and sometimes aren't street legal.
                    Correct me if I am wrong.
                    • iNetMANN
                      • 45
                      #40
                      I'm not commenting that your wrong, I'm commenting because your right.
                      SM usually implies a street legal car, but like my car which has the CAT removed, so where I live it isn't street legal.
                      (P)Prepared usually means no longer street legal but I've seen a few that were still even after all the gutting and mods but it had more to do with there local laws where that person lived, or should I say the lack of local laws?
                      RODD
                      www.M10Racer.com
                      • hoyabmw
                        • Dec 2006
                        • 207
                        #41
                        Classing is just based on the car (unless your region has a novice class).
                        Because of the non-airbag wheel on the airbag car, you will have to run DSP. Every other mod you listed you would have been able to run in STX, but the airbag rules are very specific.
                        • hoyabmw
                          • Dec 2006
                          • 207
                          #42
                          Kind of right. You forgot the ST classes, which are meant to fall between Stock and SP. Many of the front runner SP cars are trailered to events and not street legal any more. SP rules allow modifications which make cars highly unliveable for the street.
                          The set of classes really is:
                          Stock (A,B,C,D,E,F,G,H)
                          ST (S,S2,X,U)
                          SP (A,B,C,D,E,F)
                          SM/SM2
                          Prepared (X,B,C,D,E,F,G)
                          Modified (A,B,C,D,E,F)
                          It's kind of hard to say you progress directly from one to another--an E36 M3 will run BS, BSP, FP. A 318is runs GS,DSP. 325e/i runs DS,DSP.
                          I don't remember the Prepared and Modified classings off the top of my head. ST and SM have a different set of rules such that you really would need to check the rulebook to figure out exactly where they run. MOST 325s will run in STX.
                          The key to remember with the rule book: If it doesn't say that you CAN change something or run something, then you can't.
                          • SchnellerVert
                            • Sep 2005
                            • 3948
                            #43
                            How did you do at Maryland State Police?
                            Was working.
                            • kishg
                              • Sep 2006
                              • 2624
                              #44
                              you mis-understood. what i meant was whether the determination of which class you can run in factors in driver skill. i.e. being an autox noob, can i run with other noobs and not experts? thats how DE works typically, but i guess this is actually competitive hence the rules.
                              '91 SpecE30 #523
                              128290
                              • kishg
                                • Sep 2006
                                • 2624
                                #45
                                tks. so if i put my airbag wheel back on i can run in STX? what are the pros/cons vis a vis the two classes and should i care ?
                                '91 SpecE30 #523
                                128290
