Solo 2 Classification Help
  • Charlie
    kid tested, administrator approved
    • 6686
    Originally posted by joshh
    The M3 is in CSP (if I remember right) so technicaly his car would go to a racing class. The M3 needs to be on the same line and in the same class.
    What would that have to do with this guy's m42 318? He's a "3 series 16v NOC", stuck in DSP. The M3 is specified in CSP.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • hoyabmw
      • Dec 2006
      • 207
      -Charlie
      I think Josh was concerned about the diff. The 318is came with a 4.10 open originally, so running the M3 4.10 LSD gearset doesn't cause the car to move out of DSP. LSDs are free, as long as you stick to the right ratio.
      Kevin
      • E30Driv3R
        • May 2004
        • 1169
        i got classed in STX, i know i am no threat to the guys in there. can i run in DSP, or would that require running R Comps? which would i do better in? i am not expecting to come out there and blow the guys away... i meen shit it is my first time, and all i am hoping is that i stay on track, and dont spin out! I am not planning on running r comps until i get used to running on street tires ie. BFG Traction lol then some azenis. i know i am pretty much outclassed in all the classes i would go to, but i hope to hopefully keep up with some people eventually!
        Thanks, guys
        and sorry to thread jack!!
        Dan Zickel
        1995 M3, 1991 318iS, 1987 325iS
        • JGood
          • Jan 2004
          • 7959
          Thanks, guys
          What does it matter then? Your not going to be competing for a position for a long time unless you local region sucks. There's no point comparing yourself to others until you are consistent, and that won't be for a long time. Just run whatever you want, I would stay in STX, since you are on street tires and that's what the class is for. Technically STX would be an "easier" class, but like with my local region, STX is tougher to place in then DSP because there's only a few people running DSP, but STX is filled with modded WRX's. Your not going to do good - you have more to learn then you can imagine. Go out and have fun, don't worry about placing, it takes a lot of the fun out of it when you are learning. Also, take advantage of any instructional runs you can do, as long as the instructor is good.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • helikon06
            • Feb 2007
            • 16
            thank god i did not post a new topic on this.
            i need the same help
            89 e30 325i
            17x7 street tires
            H&R race Bilstien shoxs
            f strut bar
            cone intake
            new bushings "factory"
            urathane subframes
            drilled rotors
            carbon mettalic pads
            factory lsd
            B&M Short shifter
            2.5 custom exhaust
            think thats it for now...
            • Charlie
              • 6686
              DSP or STX, just like practically every other e30. There's really not much variety there dude.
              -Charlie
              FYYFF
              • Jean
                • 18228
                You can just run SM like me j/k
                SM does not allow for weight reduction, other than back seat/spare tire. Does DSP allow it ?
                • helikon06
                  • Feb 2007
                  • 16
                  -Charlie
                  damn dude no need to get nasty, it was just a question, if i could have made any sence out of the rule book i would not have needed to ask you.
                  • chucko
                    • Mar 2004
                    • 509
                    I think you took his response the wrong way, it didn't seem nasty to me.
                    • Skafrog
                      • 1732
                      http://www.scca.com/_FileLibrary/File/2007SoloRules.pdf
                      If you cant figure out what your car is in, you need to go back to drifting.
                      NASA MidSouth TT Director / GTS2 #018
                      Mods: Coastal PS Fluid, 10w40 Oil
                      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                      • joshh
                        • Aug 2004
                        • 6195
                        Kevin
                        I was unaware the 318 came with a 4.10 diff.
                        "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                        ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                        • LedZep244
                          • May 2007
                          • 10
                          I have the same question, but mine is
                          Car
                          1991 318iS
                          Suspension
                          -C3Motorsport Coilovers
                          -450F/750R Eibach ERS Springs
                          -Vorshlag Camber Plates
                          -Koni SA Front and Rear
                          -M3 Offset Bushings
                          Driveline
                          -Slipping clutch
                          -M3 4.10 LSD
                          318's run FSP, not DSP. Its not any more fun, just get waxed by the jetta's and GTI's.
                          • hoyabmw
                            • Dec 2006
                            • 207
                            Wrong. M42/44 engined 318's (90-92) run in DSP (16v NOC rule). M10 engined ones run in FSP.
                            • iNetMANN
                              • 45
                              Hoya is correct.
                              83-85 318i M10 (8v) goes HS, FSP, SM
                              90-92 318/i M42 (16v) goes GS, DSP, SM
                              RODD
                              2008 SCCA National Tour - Packwood, WA.
                              www.M10Racer.com
                              '4-banger 8v Racing'
                              • LedZep244
                                • May 2007
                                • 10
                                Originally posted by iNetMANN
                                Hoya is correct.
                                RODD
                                Thanks for clarifying. I didn't see any distinction in the rule book. Thats really not fair for the M42 cars.
