New 15x8 wheel coming!
  • Brian D
    • Mar 2006
    • 832
    #301
    Originally posted by Knockenwelle
    There are only a few 225/45s in existence, and the 225/50s are all around 28.5" overall diameter. I wanted to stay down in the 26" range.
    A 225/50r15 is 24" diameter.
    1973 Bavaria
    • Massive Lee
      • Sep 2006
      • 6785
      #302
      I got the word from somebody who contacted TR that despite having a lot of room in its perimeter, the wheel has a glitch in the center, near the hub. The spokes, near the hub are seem to be portruding and touching calipers from a 15" BBK. I asked to get a profile from the 15" x 8" wheel(s), and check by myself.
      Lee
      massivebrakes.com
      • nefarious7907
        • Jan 2005
        • 1170
        #303
        225/50/15 should fit fine and should be in the 23.5-23.9in range, and I know they will fit with slightly rolling the fenders on lowered e30's.
        http://www.cardomain.com/ride/657387
        • Knockenwelle
          • Jul 2008
          • 395
          #304
          Yep, you're right on the rolling diameters. I was going from memory. At any rate, the difference was almost 2"
          Lee- I'm using stock calipers with Brembo blanks for now. Shouldn't be a problem, right? I know I'll need bigger wheels for bigger brakes.
          I'm hoping 225s will fit with no fender modication with -3 deg camber and coilovers. I can already fit almost 3 fingers between the tire and the fender with 205s...
          Mike
          '91 325i track car. Mostly...
          • Massive Lee
            • Sep 2006
            • 6785
            #305
            I think that stock brakes will work allright.
            massivebrakes.com
            • GotCone?
              • Jan 2008
              • 589
              #306
              Oh, and markseven, mine's a red 91i, with an iS lip too. Hehehe...
              Where are you seeing this data? most any 225/50-15 will be 24" or less diameter.
              Build : Das Drehmoment Ungeheuer
              • Massive Lee
                • Sep 2006
                • 6785
                #307
                225mm at 50 ratio is 112.5mm per shoulder x 2 = 225mm of shoulder (top and bottom).
                If 25.4mm = 1" ---ยป then 225mm = 8.86"
                Therefore a 225.50.15 tire will have the theorical height of 15" + 8.86" = 23.86"
                Following the same calculus, a 225.45.15 tire is 22.97" tall
                massivebrakes.com
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  #308
                  I was wondering when some1 would post this...figures it would be Lee!!!!
                  Ive met many many dudes that "know" cars...and could never do this math.
                    • 34844
                    #309
                    that's because most people think the aspect ratio is a direct measurement in MM.
                    • GotCone?
                      • Jan 2008
                      • 589
                      #310
                      now if only the tire manufactures followed this.
                      always check manufacturer spec as there are many variances even with in the same brand across models. Width & diameter varies quite a bit
                      • JGood
                        • Jan 2004
                        • 7959
                        #311
                        Yup, like Hoosier R6 225 = Victoracer v700 245 in tread width.
                        It all depends what the manufacturer considers "usable tread". I guess Kumho thinks the sidewalls are part of the tread, and Hoosier thinks the tread stops 1/2" before the edge of the tire...
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • MDryVur
                          • 395
                          #312
                          whatever happend to these wheels.. will they be available in gold.
                          • Elephant
                            Site Sponsor
                            • Jan 2008
                            • 328
                            #313
                            I've not kept up with checking on these as it's been so long. I believe they are soon to be available though, I received a pic of a real wheel that has arrived but not sure on how many and what sizes might be available. Tire Rack site says 12/24, best bet is to call them. You can ask for Bernie if you don't have a contact.
                            They will not be available in gold. Unless something changes I'm pretty sure they are only coming in the carbon gray.
                            Cheers.
                            Jack Money
                            http://www.Elephant Motorsports.com
                            >> AST 4100 for BMW E30 $1649 <<
                            AST Monotube Dampers and Coilover Kits - Full Service Dealer
                            Schroth Safety Products Distributor
                            BMW Replacement Parts - 24/7 Secure Online Ordering
                            • bmwpower
                              • 1556
                              #314
                              Looks nice!
                              89 325is track project / 05 x5 / 99 M3
                              E30 stuff for sale | Parts I'm looking for
                              • kishg
                                • Sep 2006
                                • 2624
                                #315
                                glad these are finally coming. tks jack for getting this going.
                                '12 F30 328i Sport Line
                                '91 SpecE30 #523
                                '00 Ford F-350 Dually Tow Vehicle
                                BMWCCA #360858 NASA #
                                128290
