32mm Clutch Fan Tool - Can I borrow it?
  • marshallnoise
    • Sep 2013
    • 3148
    Does anyone in North County have a 32mm Clutch Fan Removal Tool I can borrow? I just need to get my clutch fan off cause I am going e-fan.
    Thanks!
    Paul
    Si vis pacem, para bellum.
    New Hawtness: 1995 540i/6 Claptrap
    Defunct too: Cirrusblau m30 Project
    Defunct (sold): Alta Vista
    79 Bronco SHTF Build
  • Dj Buttchug
    • Jun 2010
    • 7688
    i do but im not in north county
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • wilholl
      • May 2012
      • 518
      Thanks!
      Paul
      A long punch, bar or screwdriver and a hammer will usually loosen the nut.
      Just place the driver on the point of the hex and wack it with the hammer.
      It should loosen in 1 or a couple of hits
      1988 325 non-letter Seta "Bronzit"
      1991 325ic "Laguna Green" (Sold)
      1993 325i "Laguna Green/Silver" (Sold)
      1998 528i "Artic Silver" m-sport(totalled by drunk driver)
      2000 528i Titansilber/gray m-sport
      2000 528i Titansilber/black m-sport(sold)
      2001 525i Anthracite m-sport(sold)
      2013 750i Black/Black m-sport "Beast"
      • kronus
        • Apr 2008
        • 13032
        use the tool kit pliers
        cars beep boop
        • marshallnoise
          • Sep 2013
          • 3148
          DJ, where you at?
          Wilholl, that's a great idea but I don't want to ruin the water pump bearings. Last resort.
          Kronus, I will look and see if I have those pliers in the kit.
          Thanks fellas!
          • Chilezen
            I weld cats
            • Dec 2013
            • 1942
            I'm up in LA, and I'm glad I purchased one, because I've had several instances when I needed to remove the fan. I'd say it's worth the price if you can find it at your local hardware store.
            Definitely don't attack it with a punch & hammer.
            When removing it, I just hold onto the belt to keep the pulley from turning. Results may vary.
            Currently building a badass coffee table
            Random stuff on insta @kevanromero
            • marshallnoise
              • Sep 2013
              • 3148
              Roger that Chilezen. I will check and see if Horror Freight has one.
              • marshallnoise
                • Sep 2013
                • 3148
                I just checked out Home Depot and they have one available there for $14 bucks and I can buy it tonight. I was mainly looking at expediency as opposed to price. Vatozone didn't have one so I figured the hardware stores wouldn't have one.
                Thanks for the suggestions folks!
                • wilholl
                  • May 2012
                  • 518
                  DJ, where you at?
                  you don't have to smash it with a lot of force. More like a couple of firm sharp taps at the tip of the hex on the fan nut. It comes right off easier than you can believe. I have been doing it this way for years (old school method)
                  BTW, I do have the removal wrench and holder and use them regularly, now.
                  But in a pinch, the other way works
                  • marshallnoise
                    • Sep 2013
                    • 3148
                    Its funny you mentioned that method. The nut looks to have been beaten in a very similar method. To the point I couldn't get the nut off the water pump at all with the new wrench I just bought.
                    • ButtJuice
                      • Dec 2009
                      • 2609
                      Adjustable pliers work well, I promise.
                      1991 318is - Sold
                      1986 325 - Sold
                      Instagram - Lamoursum
                      • noypi2
                        • Jun 2014
                        • 442
                        Paul, the Home Depot 32mm open wrench is thicker....but might work. By the way, the clutch fan you gave me won't work. The fan blade are facing opposite with the one I have.
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          That's a bummer! Sorry about that! At least it was freeish.
