Help with smog result interpretation
  • Tinkerer007
    • Mar 2013
    • 252
    I am having trouble passing smog with my '84 635. The initial advice was to replace the cat. I did.
    It is still having high nox at 15 mph.
    I tried adjusting the spring 2 notches on the AFM to riches it up. Now 25 mph doesn't pass because too rich, and 15 mph is still too lean.
    Car just had a tuneup and the camshaft was worn.
    What else should I look at?
    (The papers have it as a 3.2 liter because it is '84. But it is a 3.5 liter Euro.)
    Sent from my VS995 using Tapatalk
  • reelizmpro
    • 9558
    Are you getting the car really hot by running it on the freeway a while right before testing without turning the car off?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Tinkerer007
      • Mar 2013
      • 252
      My mechanic took it to the test. He did nit get the cat hot.
      But, isn't the problem that it is lean in the 15 mph test?
      What sensor in the car is different? The from is very similar, so the afm input should be similar. Is it the throttle position sensor input that is different?
      • reelizmpro
        • 9558
        Right, I was just curious if you got the cat nice and hot. It appears it's doing it's job. I would suggest running SeaFoam through the intake to try and get rid of any carbon build up especially if you haven't done it and it's a high mileage engine. Inadequate engine cooling also increases NOx. Change the coolant recently? If not, try an 70/30 mix of Distilled water/coolant. A trick is to run the heater and make sure the smog tech uses a fan in front of the car while testing as well. Is your car automatic?
        88 M3 - LACHSSILBER
        • Tinkerer007
          • Mar 2013
          • 252
          The temperature gauge looks to be in normal range, below half way.
          I have about 280K miles, but the head was replaced 30K miles ago.
          Car is a manual.
          • reelizmpro
            • 9558
            The disparity between 15mph and 25mph while running at about the same RPM's is strange. Have you considered trying another smog station?
            88 M3 - LACHSSILBER
            • 2mAn
              Señior Mod
              • 21053
              swap in the S38
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • Tinkerer007
                • Mar 2013
                • 252
                Originally posted by 2mAn
                swap in the S38
                Yes, this option was discussed.
                • TheRob
                  • Oct 2016
                  • 204
                  Have you tested the 02 sensor to see if its switching properly? It plays a very important roll in getting the cat to function properly. Is this a euro car with a euro DME? Because that could be a problem. If its a just a USDM car with a euro engine its fine. I spent a lot of time trying to diagnose a smog failure on a Porsche, it turned out to be an ROW euro market car and would never pass no matter what I did because cars in Europe from the 80s don't have the programming to use the 02 sensor to keep the cat working properly.
                  • McGyver
                    • 4636
                    that's a fucking interesting nugget of info! would a euro DME have a different label number?
                    • TheRob
                      • Oct 2016
                      • 204
                      I'm not sure, on that Porsche someone had wired in an 02 sensor to try and get it to pass but it did nothing. I'm just wondering if this is a grey market Euro car or has been swapped with a euro 3.5 running a euro DME. Mind you this was a Porsche and not a BMW but it could definitely play a roll. I know they used to use a separate fuel control module to federalize grey market Porsches.
                      Also the numbers always go rich when you hit 25 mph even if its just slightly rich. And like OP said, he adjusted the the AFM and now its good at 15 mph but theres a lack of fuel control at 25mph and prior to adjusting the AFM there was a lack of fuel control at 15 mph. Seems like a suspect 02 sensor possibly.
                      Test 1
                      15mph - AF ratio = 15.3/1 (lean)
                      25mph - AF ratio = 14.65/1 (slightly rich)
                      Test 2
                      15mph - AF ratio = 14.7- stoich (perfect)
                      25mph - AF ratio = 14.36 - rich
                      • Tinkerer007
                        • Mar 2013
                        • 252
                        It is a gray market car. I have passed smog in the past, but it is always a struggle.
                        The O2 sensor does change, and the car runs differently if it is unplugged. My mechanic thinks the O2 sensor is working. I have a volt meter hooked up to the O2 wire and can see it changing values as I drive, and it behaves differently after I adjusted the AFM to richen it up.
                        The ECU is an 011. And it has the low impedance injectors. I didn't think the ECU had an O2 input, but it is wired into the ECU (it was spliced in).
                        I was thinking that the AFM would be at the same value at both the 15 and 25 MPH tests because the RPM is similar. But after thinking about it, the throttle would be open more, and that would let more air in (to get more power for the 15 MPH test, they say it is twice the power required for he lower speed test).
                        Out thoughts are that it is either the AFM, or the ECU. (But maybe it is worth trying a new O2 sensor. I have replaced it, but can't remember when.)
                        • TheRob
                          • Oct 2016
                          • 204
                          Its not just that the 02 changes but how quickly it changes. If your 02 slows down the AF ratio is thrown out of balance and yes at 25 mph you are under more load so you are getting more air. If its switching at a slow pace under steady state cruising you're likely looking at a faulty 02 sensors. It's all about balance and if something is out of balance with fuel control it changes everything.
                          • Tinkerer007
                            • Mar 2013
                            • 252
                            I think the 15 MPH test is more load than the 25 MPH test. I searched the internet and found this reference:
                            There are four parts to the smog test. 1) Vehicle Identification The smog test technician will enter your VIN number, Odometer reading a...
                            The 50/15 test in which the automobile is subjected to 50% of maximum engine load conditions, encountered at the Federal Test Procedure, at 15 mph. Next the 25/25 test is executed where, as you might have guessed, the vehicle is run at 25 mph at 25% load conditions.
                            I guess I will try a new O2 sensor.
                            Thanks for the comments.
                            • TheRob
                              • Oct 2016
                              • 204
                              Yep had a bit of a brain fart there, lol, one of the reasons I don't post before noon...foot meets mouth.
