Colorado general chat...
This is a sticky topic.
  • Iannfld
    • 327
    #2956
    Interesting reading..... Few things:
    My s52 e30 passed emmisions with the dash full of warning lights. No issue. I'm running custom exhaust with aftermarket cat.
    I'm running an e30 m3 driveshaft, but I'm near certain the 328 one discussed works. Just avoid the one with the cv style joint.
    I have receipts and records for all the parts I bought. I did not do a budget build, so there is a huge list of replacement "while you're in there" parts. I have 15k miles on mine without issue, so I'm glad I spent the money.
    No way I'd run a 4.10 with an e36 trans. Mines running a 3.25 and that's plenty short.
    I'd be amazed if you didn't go over budget with a swap, unless you have a pile of time to trouble shoot and Pilage the parts yards yourself.
    Sorry - still waiting on the new interior. My trip to get it keeps getting pushed out.
    Ian
    • blefevre
      • Dec 2008
      • 4287
      #2957
      Ian
      I am the kind of person that replaces all "while you're in there" parts. I can't see me doing it for cheap. I just hope I can do it cheaper then just buying a swapped car.
      Keep me updated with the interior.
      - E30, DSM, Golf R, Mazda 3 Skyactiv
      • Iannfld
        • 327
        #2958
        Here's a quick list of what went into mine. I have all part numbers in a binder at home. Drop me a line if you want more info.
        I do sometimes miss the sound of the M20 though!
        S52 bottom end
        S50 OBD1 Head and intake manifold, rebuilt with new valves, valve stem seals and valve retainers, headgasket, valve cover gasket, VANOS unit
        M50 wiring harness
        New S50 chain tensioner
        E34 Base pan and dipstick, new basepan gasket
        E28 Motor mounts
        New S52 belt tensioner and pulleys
        New belts
        E36 M3 Transmission
        E30 M3 driveshaft
        New center support bearing
        New Guibo
        New water pump
        New Thermostat
        New thermostat housing
        New Intake manifold gaskets
        24 lb injectors
        Euro HFM
        Turner Motorsports chip
        K&N cone airfilter
        318ti trailing arms
        318ti rear brakes
        E30 3.25 lsd
        M Roadster front brakes and hubs
        New wheel bearings
        Ground control coilovers
        Ground control camber plates
        Ground control rear shock mounts
        Koni shocks
        Racing dynamics sway bars
        95 M3 steering rack
        New E36 tie rods
        96 M3 headers
        97 M3 control arms
        Offset control arm bushings
        Ireland Engineering SS catback
        Aftermarket Cat with custom exhaust
        New clutch, release bearing, and slave cylinder
        New starter
        E30 radiator
        KMAC trailing arm bushings
        Powerflex subframe bushings
        E21 brake booster
        E21 fan
        BBS RGR wheels
        Falken Azenis RT615
        M tech II Wheel
        M Roadster Shifter and new bushings
        E46 ZHP weighted shift knob
        • iamsam
          • Jun 2008
          • 176
          #2959
          Ian, it has been decreed that we need more pics of your car/build.
          • blefevre
            • Dec 2008
            • 4287
            #2960
            Imagine a perfect E30 and that pretty much sums it up.
            • Bimmerman325i
              • 6854
              #2961
              Ross, I'd love that document as well!
              Ian, awesome build!
              2017 Chevrolet SS, 6MT
              95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
              98 M3/4/5 (stock)
              • iamsam
                • Jun 2008
                • 176
                #2962
                Ian, awesome build!
                David, you have no E30 nor any plans to get one!
                • monkeytaco
                  • Jan 2010
                  • 882
                  #2963
                  Ian, your car sounds awesome, you must show up to a gathering soon.
                  I'll get you guys the document soon, it needs a bit of time spent cleaning/organizing before I "publish" it.
                  The only thing I didn't do to mine is refresh the valvetrain. Considering a few more parts I've sold my net cost is $1610 and change. Gross cost(which doesn't include parts/cars sold) is at $3180. I bet with the parts left to sell I can break even or maybe even profit!
                  Looking for a clean e30 shell for a project.
                  • Bimmerman325i
                    • 6854
                    #2964
                    Always in motion, the future is.
                    98 M3/4/5 (stock)
                    • Cloudbase
                      • 1795
                      #2965
                      I second that! I think you are crazy to give up heated cloth seats for leather. The RGR's look tits too, can't wait to get mine mounted.
                      JOY IS AN E30...
                      • monkeytaco
                        • Jan 2010
                        • 882
                        #2966
                        Hurry up I want to see it rollin on bbs!
                        Speaking of rolling, is the engine sorted in your alpine now Alex?
                        • blefevre
                          • Dec 2008
                          • 4287
                          #2967
                          Pretty sure they aren't heated, but still 10/10.
                          • Iannfld
                            • 327
                            #2968
                            There's a few pics post swap at the bottom of the page below. The pics up top are real old (7or 8 years) and pre swap. I need to get some good shots the spring when it gets out of storage.
                            • iamsam
                              • Jun 2008
                              • 176
                              #2969
                              Www.cardomain.com/Id/iannfld
                              yep I did some snooping and checked that out before I posted, but we need more/better pics!
                              • stoliver54
                                • Apr 2004
                                • 312
                                #2970
                                Originally posted by Roland H
                                I would kill this mofo if he was my lawyer, out clubbin and brings a hooker to my trial. What a douche. The worst part is the case is deciding a life sentence!
                                Wheelgap is like a vagina. The more fingers you get in, the worse it is.
                                Originally posted by Chachi
                                young chicks are not keepers. they are for fun.
