Colorado general chat...
This is a sticky topic.
  • Bimmerman325i
    • 6854
    #5131
    Originally posted by Bishop
    No, he's got some Wilwoods he put together himself... He just listed what all his roller stuff was in the build threads.
    depends on rotor diameter what minimum wheel size, not caliper.
    2017 Chevrolet SS, 6MT
    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
    98 M3/4/5 (stock)
    • Bishop
      • 4913
      #5132
      ..... You nit-pick like a sun'of'abitch lol...
      PM me for detailing services in the Longmont / Boulder Area in Colorado!
      Originally posted by DTM190
      "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
      • Bimmerman325i
        • 6854
        #5133
        not nitpicking, just pointing out.
        98 M3/4/5 (stock)
        • Bishop
          • 4913
          #5134
          • Bimmerman325i
            • 6854
            #5135
            Bruno Senna is a badass motherfucker.
            He recorded an exhibition day at Spa-Francorchamps with his cell phone driving the Lotus Renault R30 F1 car. One handed. Through Eau Rouge. Backwards.
            Holy fucking shit guy is badass.
            98 M3/4/5 (stock)
            • Eric
              • 5142
              #5136
              Originally posted by Bimmerman325i
              Hm. Is your exhaust aftermarket? You might want to just go with a custom 3" or 3.5" (S54 gets most hp from the 3.5, euro might too) and lose a significant amount of weight. Also switching the tires from the 18x10s to a lighterweight 18x10 (Dforce/Apex) if you really like 285 grip OR going to the 15x8/225 RS3 combo.
              Is your car caged at all? Speakers? LTW Battery?
              autopower 4 point with a horizontal bar
              recaro pole position SPG's
              non adjustable floor mounted seat mounts
              Scroth 6 point latch link harnesses
              smaller than stock battery but not a light weight one. the front is the heavy part, so i'm not too worried about the back, in fact I might toss the spare in for a bit more rear bias.
              I'm running 18x9.5 and 245/35/18. 18x10 and 285's might fit, but I cant afford that, and I doubt i'll be able to turn the wheel much! I can't fit anything smaller than 17's because of the big willwoods, and honestly the car needs more tire as it is, so going to 15's would be just a smoke show.
              at MSR, I put down a 1:29 in my first session. The locals said that was a really good time, and I could have shaved a few seconds if I wasn't so timid with the non power assisted brakes. Oh yeah, super custom booster delete! -2lbs!
              Here is the exhaust I have. http://store.vacmotorsports.com/vac-...tem-p1914.aspx
              VAC claims it's 1/2 the weight of the stock E30 M3 exhaust. I think beyond cutting up the floor pan and doing a sup cool side exit shorttie exhaust, a 3" won't do much for me. I was thinking though, that the stock E36 M3 exhaust has the x pipe behind the cats, where the E30 M3 (and my exhaust) has the exhaust much much closer to the motor. I wonder if that is why the power was a bit lower 229rwhp, and the torque was high 250fl/lb.
              • Bimmerman325i
                • 6854
                #5137
                Sounds like the exhaust is super restrictive. A good full 3" (on an e36 m3) weighs less than just the stock muffler section, so I bet there is tons of weight to be lost and power to be gained going to a single 3" from the headers back. Boulder Muffler would be able to do it quite well.
                I'd go with 17x9/255s then. Great combo, or the 17x8.5/245/40/17 Kosei K1 setup. The Koseis are quite cheap, not as strong or light as the Dforce/Apex/TR wheels, btu cheaper and plenty fine.
                Have you thought about putting assisted brakes and power steering back in? Losing the weight but being unable to turn or stop the car comfortably seems like the wrong way to go.
                98 M3/4/5 (stock)
                • Eric
                  • 5142
                  #5138
                  It's the 3.0L Euro, making about as much power (stock) as a bolt on S50/OBD1 S52, so the 15s/225s would work well. I'd rock the 18x10 Dforce or Apex and 285s personally, or a 17x9/255 combo since he does have the fender flares to fit it, but 15s wouldn't be too bad if paired with a sticky tire.
                  I do have a set of 17" RS's that could get widdened. 255/40/17 on all 4 corners? I'm not sure if 285's would fit, plus wouldn't that be more weight???
                  Can't run 15's because the wheels won't clear the calipers. 17's clear just barely.
                  Not to be nit pickey, but I bought the kit complete. It's not lee's kit, but I didn't build it either
                  holy shit, that was badass!
                  • Bimmerman325i
                    • 6854
                    #5139
                    I wouldn't run the RSs, they're far too heavy. I'll leave tire discussion for Chris, but since I was wrong and you can't do 15s, I'd get lightweight 17" wheels and run a 255 on it.
                    98 M3/4/5 (stock)
                    • Eric
                      • 5142
                      #5140
                      Sounds like it's time to hack up the floor plan for a side exit! That means I can ditch the spare tire well and add a diffuser behind the diff. yaay!
                      This is totally personal preference, but I HATE the Kosi's. Never liked what they look like. Also the Kuhmo's have one track day on them, so it will be a while before I revisit tires. Although my white BBS RC's could shave a few unwanted pounds...
                      Never got a power steering pump with the swap, and honestly, it's quite easy to drive without power steering. A booster doesn't fit in the engine bay any longer. The difference between boosted brakes and non boosted is hugely different! Your legs are conditioned to press on the brake pedal a certian way, and when you have to re-learn how hard to push all over again, it's a bit of a learning curve. Try driving smoothly with your left foot doing the gas pedal instead of it's normal clutch duty... it's really wierd!
                      Yeah, and they will look nicer on the M5 :up:
                      255/40/17 hankook RS-3's are only $476 for a square setup from tire rack! That's an awesome price!
                      • Cloudbase
                        • 1795
                        #5141
                        Geeking about how much weight to loose is a slippery slope. It sounds like you have a few more pounds to loose, but all the appreciable stuff is gone and the cost / reward curve is getting exponentially steeper for small gains. I used to geek about my bikes when I was in the peak of my mountain bike racing. Swapping out normal allen nuts for ti nuts, carbon fiber bottle cages, ti skewers, etc. Once the major stuff was gone the gains were costly and small. Taking a big dump before the race would net more gains than $400 of new hardware! God speed my friend, god speed!
                        My bro just got Hankook RS's for his WRX and loves them. Incredible bang for the buck. He's thinking about getting them for his M Roady, but that is on the market so probably not.
                        JOY IS AN E30...
                        • Cloudbase
                          • 1795
                          #5142
                          I got my E30 back from Autosport Werks today. I freakin put my washers on the wrong side of the drop hat, causing massive alignment float. Roland helped me take the shock assemblies out and right my wrong. It went so fast with someone who knew what they were doing and two people. Thanks man!
                          I'm going to try to snap a few pics tomorrow. I really like the stance. With some 10mm spacers it will be perfect. I think the 17's look great, I take back what I said about thinking they were too big.
                          Until I get some E30 pics here are a few from my travels (sorry for the crappy cell phone pics).
                          Badass F430 on my vigirous walk to Starbucks in Palm Springs, CA
                          Heavily Modded Kiss Themed Ford Focus valet parked at the Red Lion Hotel in Pasco, WA. No Kiss was not in town that weekend, this was somebody's DD!
                          Awesome Split Window in Boulder today. This thing passed me on the right going up the hill on 36. It was swapped with something powerful and watercooled. The radiator and coolant reservoir are mounted outside on the driver's side. Forward of that is a single bike tray at a reachable level. It was fucking awesome!
                          JOY IS AN E30...
                          • Roland H
                            • 4480
                            #5143
                            No problem dude, glad we got that squared away!
                            • stoliver54
                              • Apr 2004
                              • 312
                              #5144
                              Don't do 15s w/ the Euro motor.
                              No one like my video? I sad
                              I did like your video and it looked bad ass, something I would like to get into. But there were many conversations going on and I did not wish to interrupt.
                              Feel better now Ben?
                              Wheelgap is like a vagina. The more fingers you get in, the worse it is.
                              Originally posted by Chachi
                              young chicks are not keepers. they are for fun.
                              • Bishop
                                • 4913
                                #5145
                                I <3 Sean. Text me though if you have questions, I'm happy to help. It's a blast
