Do his windows and mirrors not work, also?
PNW Chit Chat thread
Yep, not a fuse either.Alpha Team Inductee
2014 Icon E-Flyer
2013 Zboard San Francisco Special
2010 Buell XB9SX
2009 Harley-Davidson 883 Iron - "Xerces"
1991 BMW 362iS Touring - "Stephanie/The Death Machine 2.0"
1974 Honda CB360/CL360 Scrambler Project
1971 Honda Trail 90 - "Stephen Parish"
2008 Saab 9-3 Convertible
2002 Mazda Miata LS
Oops, they do work*
Just the blower is dead.Alpha Team Inductee
2014 Icon E-Flyer
2010 Buell XB9SX
2002 Mazda Miata LS
Ok, thanks for clearing that up. Sounds like a dead motor or maybe an issue with the wiring. I'd pop the cover off and make sure you're getting power to the fan. If you are, you can assume that it's dead, but they don't usually just die with no signs of warning...'72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
Mine died a few years ago at random, but usually it's the resistor, which we did switch out.
Do you know where the contacts are to run a multimeter against? Or where would you test it?Alpha Team Inductee
2014 Icon E-Flyer
2010 Buell XB9SX
2002 Mazda Miata LS
Originally posted by OldDrunkenSailor View PostMine died a few years ago at random, but usually it's the resistor, which we did switch out.
On the actual fan motor itself, there are two wires leading off it. One of them will be brown (ground, obviously, I forget the color for the hot wire.) Use your DMM and see how much power is going to it. If there isn't power going to it, well, then you know your issue.
Was the resistor used a known good working one?'72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
Check power going to the non-ground, you mean, right?
Well the resistor came out of my car years ago. I thought that the resistor was dead, switched it, things were still dead, got a new blower motor, and things worked. So I'm pretty sure that my motor was dead all along and that the resistor was actually ok. So that's what we're banking on now.Alpha Team Inductee
2014 Icon E-Flyer
2010 Buell XB9SX
2002 Mazda Miata LS
Originally posted by OldDrunkenSailor View PostCheck power going to the non-ground, you mean, right?
I would definitely have checked all the solders on the resistor before you installed it, but it's not a big deal. I went through a similar issue last winter where my motor bushings were fucked and squealed like mad and one of the solders broke off on my resistor, so the fan would only come on when on highest speed (four.)
I'd look to that for being a possible issue, but if you say it's good, then check everything else.'72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
Cliff notes version = the blower started to intermittently start to not work, when it did work it would switch to different fan levels (1-4) with no problems. then all of a sudden it doesn't work :/ I checked the fuses and noticed one was blown. changed it and vuala, All is well..... until later that night, no blower again. Idk. Joel and I tryed to swap one of his old blower switches, then the resistor without any change. I suppose its time to check for power to the motor (thanks Austin). I believe Brown in typically the ground, ill check for pwr to the motor ( the wires are accessible). no heat in the rainy cold winter sucks, hopefully i can get to the bottom of this soon :)The greatest honor an e36 could ever have... to be parted out and have its parts used in an e30.
The difference between a porcupine and BMW’s. BMW’s have the pricks inside.
Originally posted by Silva-S50 View PostCliff notes version = the blower started to intermittently start to not work, when it did work it would switch to different fan levels (1-4) with no problems. then all of a sudden it doesn't work :/ I checked the fuses and noticed one was blown. changed it and vuala, All is well..... until later that night, no blower again. Idk. Joel and I tryed to swap one of his old blower switches, then the resistor without any change. I suppose its time to check for power to the motor (thanks Austin). I believe Brown in typically the ground, ill check for pwr to the motor ( the wires are accessible). no heat in the rainy cold winter sucks, hopefully i can get to the bottom of this soon :)'72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
