M20 engine build
  • kid325e
    • Sep 2007
    • 6421
    #31
    I get you! I appreciate it man.
    I hope you have a great Thanksgiving as well. The name is spelled Paolo btw.
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • e30josh
      • Sep 2004
      • 718
      #32
      The op is probably lurking... I do agree that the stock form m20 can handle a lot more of a beating.
      Were talking track/race engine here, and if you think a stock 24v with no oil cooler is gonna last long. Well, your probably high or have never driven it hard enough to figure out.
      Most of the 24 valve cars I've seen/ driven at the track heat up and stay hot, and start to clack by the end of the season. That's in 75 degree Washington weather, I could only imagine trying to race one in real heat.
      • 4ce30
        • Feb 2006
        • 2762
        #33
        Originally posted by EN318isPDX
        I fail to see any logic in this statement
        Do you track your car? Have you ever drove an e30 hard or do you daily your car? If you knew where I'm coming from you'd have to actually take your car on the track and I'm not talking once or twice. My statement is 100% based on my experience behind the wheel of an e30 on the track 60-70 events. If i used my e30s for daily duty and putting around getting on it every once in a while then yea I'd go m50 but the truth of the matter is they are not built to take the abuse an m20 can. The oil basically starts boiling and eating up your top end and this is ridiculous they should have put oil coolers on them.
        • 4ce30
          • Feb 2006
          • 2762
          #34
          Here's my first track car m20 powered 40 events still running to this day!
          Here is my m50 e30 lasted 9 events before the top end starting starving itself of oil.
          Here's one of the last events I took the m50 to if you listen closely throughout you can hear it cutting out and not producing any power
          Now you know what we use our e30s for and why m50s aren't half the motor the m20 is. Have a great day everyone and enjoy your e30! I know I have for the past 10 years and 20+ e30s I've been through!
          • timmyr77
            • Jun 2012
            • 353
            #35
            I've had an old worn out 2.5i in my car and vs my rebuilt 2.7i it's crap. I've driven m50 e30 they drive a lot differently so I'd see if I could get a ride in a few cars before doing anything. Also having done pulls with m50 swapped e30s I'm happy to say that I pulled or kept even with the m50s every time (keep in mind I have the heavier vert as well) I say build the 2.7i. If you are planning to boost in the future do everything the first time through so you don't have to second guess anything later on. Listen to the guys that have done the build not the ones who just talk crap every chance they get.
            • mcdougal
              • Nov 2014
              • 251
              #36
              So if you throw an oil cooler in an m50 does it improve their track life quite a bit.
              • 4ce30
                • Feb 2006
                • 2762
                #37
                ^ I think it would help a lot and most likely solve lot of the problems I was having. I just got fed up and wasn't very impressed with the power increase at all. 15 hp more and all that work/time to swap just was ridiculous for me. I beat the hell out of my cars soo I'm going to be biased towards a solid engine versus a 10% increase in power.
                • James Crivellone
                  Head Janitor
                  • 6304
                  #38
                  Complete opposite for me.. I've been through so many rocker arms I cannot even count, snapped oil pump shafts, bearing issues, blah.
                  Hell I saved my Pro3 season by dropping an M50NV in the car.. no baffle, no cooler, ran the crap out of it, including several endurance races.. didn't have a single issue
                  • Wschnitz
                    • 8089
                    #39
                    But but but criv, drifting is more intense then endurance racing! Obviously your m20 is crappy and isn't a good sign of reliability.
                    willschnitz
                    • 4ce30
                      • Feb 2006
                      • 2762
                      #40
                      You can run m50s in pro3!???
                      I don't know what to tell you other than I think drifting is a lot harder on an engine than road racing! Your shifting through gears down shifting breaking ect while I'm in the same gear all day at redline clutch kicking to keep it at a higher rpm. I've road raced, auto x drag race done it all and I can tell you you are not going to work your car harder than out drifting! Maybe try it once guys instead of bashing it. Op is building his car for drifting and that's why I'm here to give valid data of just that. Enjoy your car have a good day namaste!!!😎
                      • Wschnitz
                        • 8089
                        #41
                        "drifting harder on engines then endurance racing"
                        kek
                        willschnitz
                        • EN318isPDX
                          • Oct 2007
                          • 4373
                          #42
                          I am no mechanical engineer but based on the designs of each engine I would say 24v are more rev happy than the valve train in the M20.. 1 or 2 of each motors holds no real tangible evidence. I am not even going to get into what motorsport is harder but I do notice drifters don't take very good care of their cars compared to drag racers and other real motorsports.
                          • Wschnitz
                            • 8089
                            #43
                            Bruh he just needs more zipties and DTM fiberwerkz parts and his m20 will be golden.
                            willschnitz
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              #44
                              m20 is a nice simple engine to start on but claiming its godlike is ludicrous
                              • 4ce30
                                • Feb 2006
                                • 2762
                                #45
                                I'm over it I know criv is an og and I trust is judgment the rest of you just in one ear out the other with your negative statements.
