Braising Oil lines
  • delamaize
    • Nov 2013
    • 1460
    Braising Oil lines
    Does anyone know where someone could get some AN fittings braised onto M60 oil lines, Preferably in the Olympia area? I need to mount my filter on the right side of the car, which means I need to make some longer lines.....
    Dumpster Fire Pilot
  • Matt-B
    The Waffler
    • 3856
    I have heard of people using AC shops. As it's usually the same material
    • delamaize
      • Nov 2013
      • 1460
      Thanks, I'll make some phonecalls....
      Dumpster Fire Pilot
      • lti_57
        • Oct 2014
        • 142
        House of hose here in Spokane http://spokanehose.com/ can build anything even dot brake lines cool people and easy to work with
        Directly above the center of the Earth
        • iansane
          • 1342
          I've used Williams Oil Filter service in tacoma many times. Any city that has a lot of semis coming through will have a hydraulic shop. I'd be surprised if there weren't at least one in Oly.
          84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
          • TobyB
            • 5268
            I've used silver solder with much success- MAPP gas gets plenty hot, as do even
            those butane torches that restaurants use...
            t
            • delamaize
              • Nov 2013
              • 1460
              I didn't think about truck shops, their is a few around me, I guess I gotta make a few more phone calls tomorrow. I need to get this done ASAP.
              Do you know if they will accept project though the mail? Spokane is a little far to drive to drop off and pick up.
              Dumpster Fire Pilot
              • e30josh
                • Sep 2004
                • 718
                What material are you going to be braising? I'd rather have it tig welded if possible.
                • djjerme
                  • 5082
                  I worked for Brattain International for a short time after I got out of Mechanic's school, and I built a bunch of specialty lines for my cars back then. They had all the nice Goodyear hoses/fittings for fluid lines, and all sorts of cool stuff people forget they have. Heck, I used much of the machine shop to do all my own block prep/balancing during off hours. Great resource to have.
                  2016 Ford Flex
