BMW E30 Bi-Xenon HID Projector Retrofit Kits!
What is the most commonly ordered bulb temp?Comment
84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
_(edited)_IMG_20200926_170054(2).jpg?width=1920&height=1080&fit=bounds)
I just received my retrofitted Depo’s with the Morimoto option within the 2 weeks as described in the website. Setup was packaged well; not like how you received packages from Amazon. Nice workmanship and worth the money for a product that was built with pride and care.
I had a few questions on the wiring connection and Gabe was quick to respond and very helpful; pretty impressive for someone doing this business in addition to his real job and caring for a family.
I plan to install it over the holidays. Currently, planning where to locate the relays, ballasts and route for the wires. It’s pretty much a plug and play setup.
Thanks for the feedback and kind words!! I'm glad it got there safely. I'd love to get some pictures of it when it's all done.I just received my retrofitted Depo’s with the Morimoto option within the 2 weeks as described in the website. Setup was packaged well; not like how you received packages from Amazon. Nice workmanship and worth the money for a product that was built with pride and care.
I plan to install it over the holidays. Currently, planning where to locate the relays, ballasts and route for the wires. It’s pretty much a plug and play setup.Comment
Just finished installing the Morimoto BI-Xenon kit retrofit. What a difference. I do however have a question. Do you recommend using the supplied relays and wiring direct from the battery or just reuse the existing stock wiring to power the ballast? I got the 5k Morimoto kit and the light output is great, but a bit more yellow than my 5k HID kit on Stock depo projector housing used previously....
Will post pic soon.1993 325iC
1998 M3
1987 535iS
People do it either way. I've learned that the HID bulbs are very particular to have a strong and constant 12v. As long as all the wiring is good, then you shouldn't have any problems. I used it and recommend using it because then you know for sure you're getting as strong of a 12v power supply to the ballasts as you can with new wiring.Just finished installing the Morimoto BI-Xenon kit retrofit. What a difference. I do however have a question. Do you recommend using the supplied relays and wiring direct from the battery or just reuse the existing stock wiring to power the ballast? I got the 5k Morimoto kit and the light output is great, but a bit more yellow than my 5k HID kit on Stock depo projector housing used previously....
Will post pic soon.
I would also give the bulbs a little bit of time. I noticed when I first used mine the color changed slightly after a little while.Comment
Good to know. Here is a picture of the Morimoto kit installed in Depo housing. 5000k
1993 325iC
1998 M3
1987 535iS
I think he made an updated thread about the new stuff:
Correct. Thanks for sharing.
https://www.r3vlimited.com/board/for...-retrofit-kits
I no longer make the kits for the Mini H1 projectors. The new kits use the Micro D2S or MLED projectors. Same concept, just better units and more user friendly kits/install!!!
