Feeler: custom tower braces
  • F34R
    sLaughter
    • 12385
    #31
    Originally posted by richardb
    His first post says ball park of 150-180 for fronts, not $120. I agree, the IE bar is the same as a sparco and is cheap.
    The IE one is 9 dollars less than the Sparco one. Don't worry, I am sure mine will be built better and cheaper. This is a starting point and I need to get everything in a straight line first.
    And this is another idea I have been playing around with is custom user names welded onto the center of the brace. So stay tuned, I am doing this for for us the E30 family =)
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • blefevre
      • Dec 2008
      • 4287
      #32
      Replicate the Hartge bar :)
      - E30, DSM, Golf R, Mazda 3 Skyactiv
      • der affe
        Technical
        • Dec 2005
        • 8452
        #33
        Originally posted by E30 F34R
        That is what I am searching for right now. I don't have a bender, so I have been searching for one that will be able to handle the abuse of bending steel. I looked at the 159 HF one and I don't really know how well it will make the angles needed to match up.
        I have everything needed to produce these but the bender. I was thinking about making my own dies and using my SUPER large vise to get the angles of the piping. Not kidding on how big this vise is...I clamped down my med case LSD to break bolts loose on the output shafts when they were cut and removed from the drive train.
        So my idea is right now to go with 1" 1/4(same size as my ebay alum one) tubing with plate steel bent to form around the towers. Anyone know of a steel grade that is best for making such things?
        i don't think the dies runn small enough on the HF one.
        i use a hydrolic version of this and it works well for clocking multiple angles in one piece.
        US manufacturer of CNC rotary cutters and tables, benders, and notchers. Family-owned, made in the USA, serving metalworking pros since 1982.
        i am not sure what you price range is though, but i went from a manual to the hydraulic and if you are doing volume numbers, it is the way to go and it allows greater repeatability. you can also find lots of them for sale used.
        chromo is best , but adds to the cost. you can however build it lighter with a smaller diameter tubing. you should as so tig weld chromo for the best results.
        • F34R
          sLaughter
          • 12385
          #34
          Local shop my father is friends with(used to work there, friends with owner also) is selling a bender. So hoping to buy it, I will be making custom exhausts for three of my cars. Good to have =)
          I sent you a message about the rear design and fronts in a PM. I am getting a new welder for my Bday so I am thinking about learning TIG. My father says it makes better stronger welds(he is a master welder). So I will hoping to get the new welder in a few weeks. I just have to buy tubing, get the bases from Matt-b to make the program at the machine shop. This will all be happening once my brothers repay me from buying their sets of wheels.
          I am also going to make a cage for my track car =)
          FYI to everyone that is interested in one, I will NOT be under taking this till after the 22nd this month(Gfest) I have two cars to finish in this week. If anyone knows of my stroker build, the crank and pistons are due mon/tuesday. So I am buried beyond belief with the vert and my DD that I am selling to a friend at the event.
          So stay tuned, I have had me eyes set on building these for a good while now.
          P.S. I am also talking to a water cutter to see about plates with the user name cut into it. This will be an extra charge. I just think it would be neat to have you noticed by your user name at a track while in the pits prepping =)
          Current cars:
          ~ '87 535
          ~ '06 X5 4.8is
          • straight6pwr
            • Sep 2004
            • 3450
            #35
            sparco design is the best/simplest!
            • e304me
              • Feb 2006
              • 1374
              #36
              you need to make sure it fits the m42's
              • F34R
                sLaughter
                • 12385
                #37
                Don't worry, that is the route I am taking =)
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                • Holland
                  • Nov 2008
                  • 7176
                  #38
                  I am definitely interested to see the final product. Camber plate clearance would be a huge plus!
                  Originally posted by DEV0 E30
                  • F34R
                    sLaughter
                    • 12385
                    #39
                    That is one of the main reasons I am making this. I mean you do a search for braces and there is next to nothing. If you find something that works it is made in China, backordered or wicked expensive. I am trying to solve this problem because I am a tracker to the core. I just get pissed when I cannot find what I want.
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • downforce22
                      • Aug 2009
                      • 3190
                      #40
                      I knew this would come up when I first posted it. My buddy that works at BMW owns an iX. So I am hoping that he will let me mock up one, so I can produce a batch.
                      looking forward to what you come up with, keep it updated with the ix specific progress
                      • Holland
                        • Nov 2008
                        • 7176
                        #41
                        As long as it can clear the M10 and my future S14, I will for sure be interested.
                        • Matt-B
                          The Waffler
                          • 3856
                          #42
                          there in the works guys, stay tuned :)
                          • F34R
                            sLaughter
                            • 12385
                            #43
                            These are the cars I am putting on top FIRST:
                            24v swaps(I am making it off mine) At the same time on my brothers vert m20 stroker.
                            Then 318(all) and 325ix(buddy owns one)
                            M3 is last then the carbon fiber ITB ones. I will contact SickazzE30 when that time comes. I am taking one step at a time.
                            I am dead set on this, and the design changed. I know everyone will love it =)
                            Think mason and hartge
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • enigmaticdream
                              • Jan 2010
                              • 572
                              #44
                              Oh, I'm stoked. I'll most likely be down for a set when they're ready for purchase.
                              1986 911 Supercharged Frakenstrat/Stripped
                              1987 325is Delphin/Black (Olga)
                              1988 M3 Zinno/Natur (Elsa)
                              Manual or STFU
                              E30 Chapter of BMW Car Club of America
                              E30 Oktoberfest 2017
                              • richardkeith97
                                • 1693
                                #45
                                def in for a set.
