E30 Multiple Part Outs - Post 55 - Wrinkle Black VC, Cluster Parts, ODO Gears, etc
  • AWDBOB
    • Aug 2013
    • 4386
    Viscous Coupling sold.
    • AWDBOB
      • Aug 2013
      • 4386
      Trailing arms, subframe, axles, and front strut tower brace sold!
      • AWDBOB
        • Aug 2013
        • 4386
        Door sill and engine harness sold! I've got late model coolant reservoirs, a good sedan passsnger front door seal, iX flares, 885 cylinder head, etc all just waiting to go on your car! Let me know whatcha need.
        I also have a manual iX drivetrain swap, extra 4.10 front and rear differentials, e30m3 rear hub setup, etc.
        • ATL_E30
          • May 2017
          • 240
          PM'd
          • AWDBOB
            • Aug 2013
            • 4386
            Originally posted by ATL_E30
            PM'd
            Intake manifold manifold and TB sold!
            • ForcedFirebird
              • Feb 2007
              • 8300
              PM sent
              john@m20guru.com
              Links:
              • Big swifty
                • Mar 2013
                • 83
                Bump for a great seller. Parts received...thank you.
                • AWDBOB
                  • Aug 2013
                  • 4386
                  Originally posted by ForcedFirebird
                  PM sent
                  Returned!
                  Thanks again- enjoy the door sill!
                  Fuel sending unit sold, 325i cluster pending.
                  • AWDBOB
                    • Aug 2013
                    • 4386
                    Bump
                    • AWDBOB
                      • Aug 2013
                      • 4386
                      4.10 Front Diff and Silver iX flares sold!
                      • NEOe30
                        • Jun 2016
                        • 415
                        Will that 325e starter fit a getrag 260 trans w an m20 flywheel? I think it should. If so, interested
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          yes. All m20 g260's use the same starter, except the k5 relay 8mm nut/wire was added in 1988. Early models only had one 8mm nut/wire, late has 2. If using an early starter in a late car, you can just ground the k5 wire and the only thing that happens is your power windows etc will work during cranking (late models drop relay voltage to stop power windows from moving while cranking). Since you have early model, you can use any m20 starter without issue, direct fit.
                          john@m20guru.com
                          Links:
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            Buy with confidence. Bob was overly accommodating when selling to a local here, and the local doesn't even have an account here!
                            Thanks Bobbie! He is super stoked.
                            john@m20guru.com
                            Links:
                            • AWDBOB
                              • Aug 2013
                              • 4386
                              Thanks, John! I finally got everything squared away at greyhound on Tuesday evening after work- I packaged them well so they should make their journey safely. I'm excited to see how his car turns out!
                              • AWDBOB
                                • Aug 2013
                                • 4386
                                Chassis harness, 525 ECU and late model starter sold!
                                I have a second manual 88 325iX I'm parting as well, so if you need anything off of that shoot me a PM.
