T-shaped ICV for m20b25
  • Tibboy12
    • Mar 2019
    • 38
    Hello!
    I’m searching for a tested and working t-shaped ICV for an m20b25. Thank you!
  • 82eye
    • Jan 2009
    • 2108
    Originally posted by Tibboy12
    Hello!
    you might have to go new. they are currently available but disappearing fast and getting more expensive every day. i might pick one up myself before they are nla like the eta valves. the cost is holding me back.
    • Tibboy12
      • Mar 2019
      • 38
      Hey,
      I’m half tempted to buy one as well.. does no one rebuild these units like other serviceable parts like the ICM and AFM? I’ve been dealing with idling issues and have tracked it down to both the ICV and AFM.
      • It's Soda Not Pop
        • Jan 2022
        • 877
        this guy might rebuild them not sure.
        Instrument Cluster Testing - Full testing of all BMW E30, E23, E24 & E28 instrument clusters. Odometer Repair - Common problem on all vintage BMW! Clear cover polishing Custom needle paint Variety...
        88' Seta 2.7i Zinno
        https://www.r3vlimited.com/board/for...430-my-88-seta
        • packratbimmer
          • Dec 2009
          • 1335
          Make sure the check valve for your charcoal canister is functioning - they fail way more often than the ICV. Make sure all vacuum leaks are repaired. I have valves if you need one. Thanks
          • jeffnhiscars
            • Jun 2011
            • 6011
            You can try cleaning it w carb cleaner but that's about it for fixes
            Alice the Time Capsule
            • Tibboy12
              • Mar 2019
              • 38
              Hey,
              I installed a new genuine check valve for the charcoal canister but still have a bit of a lumpy idle at 500rpms. Waiting on Greg at Bavrest to send back my AFM to see if that fixes the issue if not then I’ll reach back out about an ICV.
              • jeffnhiscars
                • Jun 2011
                • 6011
                Many idle issues are related to vacuum leaks. I'd do a smoke test before buying any more parts
                • ZeKahr
                  • Jul 2016
                  • 508
                  OP before throwing expensive parts at the low idle problem, I’d recommend checking your vacuum and compression levels.
                  I have the same 500 RPM idle (though not so lumpy) as you. I just checked my vacuum with the car fully warm and here’s what I got:
                  Park (yes, car is auto): 15 in Hg
                  Reverse (parking brake engaged): 14 in Hg
                  Drive (parking brake engaged): 13-14 in Hg
                  Haven’t checked compression yet, planning to have a shop do it (cuz lazy :D)
                  1986 325e Schwarz (sold)
                  1989 325iX Alpineweiß​ (daily)
                  Greed is Good
                  • packratbimmer
                    • Dec 2009
                    • 1335
                    I had a similar problem back in the day and it was the stock chip in the ECU. When I switched to a SSSquid chip the problem vanished
                    • ZeKahr
                      • Jul 2016
                      • 508
                      If an aftermarket chip fixed your issue then it’s probably because the aftermarket chip had more advanced ignition maps. The stock chip uses conservative timing maps to prevent engine damage in the event the engine runs lean. If you pulled out your plugs prior to installing the chip I bet they were sooty
                      Greed is Good
                      • Tibboy12
                        • Mar 2019
                        • 38
                        Hey! What do those numbers mean?
                        • Tibboy12
                          • Mar 2019
                          • 38
                          I ended up purchasing an ICV from a member on here, should get here this week so I’ll report back. In the mean time my buddy just picked up a new smoke machine so I’m going to check for vac leaks on the car. As far as ECU goes, I did let someone else try it on their car when they had a no start issue and my ecu fixed their issue and idled good.
                          • ZeKahr
                            • Jul 2016
                            • 508
                            According to my Bentley manual, it means the following probable causes:
                            a. Incorrect ignition timing (retarded)
                            b. Incorrect valve timing
                            c. Low compression
                            d. Throttle valve sticking
                            e. Leaking intake manifold gasket or fuel injector seals​
                            The Bentley says normal vacuum at idle should be 15-22 in Hg, but 15 is the border of “normal” and “problems”. Something around 17-22 is closer to “normal” vacuum according to the Pittsburgh (from Harbor Freight) vacuum gauge I have
                            Greed is Good
                            • Tibboy12
                              • Mar 2019
                              • 38
                              Good to know! I’ll have to refer back to my Bentley and see If I can find that information. Also, my AFM should be coming back from bavrest here soon so I’ll report back on those findings.
