Endurance Spec front brake kit (champcar, WRL, etc)
  • redneckvtek
    • 60
    This is a bit of a "backwards" group buy since I already have parts in hand. I asked around the endurance racing groups and got some interest, but bit off more than I was expecting. If this needs to be moved please accept my apologies.
    I campaign two E30's in the "champcar" series.
    Click image for larger version  Name:	PinkiesVIR.jpg Views:	0 Size:	71.8 KB ID:	10037634
    While we have found success on the OE brakes (My old setup was Stock Girling calipers with Zimmerman rotors. Condor supplies my brake lines, and I use PF08 or ST43 pads), the setup does have weaknesses:
    1. Rotors - The rotors last about 14 hours at most tracks, even with 3" custom cooling ducts. We have cracked rotors on many occasions, leading to some pretty hairy moments having to finish a race with a terrible braking vibration. Luck kept us from "exploding" a rotor and having a big issue
    2. Consumables Costs - The rotors get changed after ever weekend on the track, including doing "testing" or "DE" days. Pads are good for 1 Race weekend, and the left overs get used for testing and DE. The rotors are $30 each (FCP helps with this), and the front pads are $200/set.
    3. Component Sourcing - The Caliper brackets are NLA new. The guide pins are currently NLA and have been for a year or so, and I just used up my last NOS set of those plus swapped my last set of good brackets from left to right (One pin wears faster than the other). The calipers require frequent rebuilds to replace the seals, which have been intermittently available. At least this stuff is cheap when it is available.
    Looking to improve upon this, and minimize risk of rotor failure in longer races, I have designed a custom kit to fit the E30 front and work with the stock E30 rear.
    The kit is designed, as much as possible, around off-the-shelf Wilwood components. It's primary concern was minimizing ongoing consumables costs and maximizing ease of service.
    In addition, No modification to the strut is necessary. This was a critical parameter for our team since we end up replacing strut housings on a (much to often) regular basis due to damage.
    Components:
    Off the shelf items:
    Wilwood Caliper 120-13232. Forged Superlite 4 Radial, 4 Piston, 1.25" Pistons
    Wilwood Rotors 160-2898 (RH) and 160-2899 (LH). 11.75x1.25 with a 8x7 mounting pattern. Many other rotors will also work (for example HAWK HR8002R and HR8002L). For longer events I recommend Wilwood 160-13499/160-13500 Rotor (GT 48 SPC 37 11 .75 x 1.21)
    Wilwood Bobbins and Bolts 230-14845 (qty 2 required). 5/16 x .750. Locktite and Safety Wire recommended.
    Wilwood Caliper Mounting Studs/Nuts 230-13273 (qty 2 required).
    Pads - Any '7420' pad shape, which is an extremely common shape. Almost any compound can be had for <$200 in this shape.
    Lines - The Wilwood caliper is supplied with 1/8-27 NPT female threads. This means adapters are necessary.
    Custom Components, Made in USA:
    Hats, Machined from 7075-T6 Aluminum, with black anodize Type 3
    Click image for larger version  Name:	IMG_5527-Medium-rotated-e1624233792895.jpg Views:	0 Size:	99.5 KB ID:	10037638
    Adapter Brackets, Machined from 1018 Steel, with black powder coat
    Click image for larger version  Name:	ORVI2796-Medium-rotated-e1624233550351.jpg Views:	0 Size:	79.3 KB ID:	10037635
    Costs:
    I had 20 kits made. I hope I can pass enough on to recoup my investment.
    $350 for the pair of brackets
    $250 for a pair of hats
    From Me, the cost would be $620 shipped to US.
    Fixed Costs are for the Wilwood components, which you would buy direct from your preferred source:
    Calipers - $500
    Rotors - $100
    Bobbins - $100
    Hardware - $40
    Pads - $200
    and
    Lines - $100
    or
    Adapters 03122ERL - $15
    All in, you are looking at ~$1600
    I have 10 sets of "custom" braided adapter brake lines that I had made that I can sell for $100. Includes 8 brake lines (4 for the rear, two "stock" fronts (not needed) and 2 M10-NPT adapter fronts)
    Click image for larger version  Name:	IMG_5607-Medium-rotated.jpg Views:	0 Size:	42.0 KB ID:	10037637
    Technical Details:
    Brake Bias:
    With stock brakes, the torque bias (assuming equivalent pad compounds) is 67.6% front.
    With this kit in the front, and stock rear, the torque bias is 66.8% front.
    Weight:
    The rotor is 9.6 lbs per Wilwood
    The caliper is 5.4 lbs per wilwood
    The adapter bracket is 1.2 lbs
    The hat is 1.2 lbs
    Total = 17.4 lbs per corner
    Stock Rotor = 10.5
    Stock Caliper and Carrier = 8.8 lbs
    Total = 19.3
    With Pads, the weight is basically a wash.
    Fitment:
    This is the biggest downside to the kit. It was designed as a no-compromises kit for our race team. We run 15x10 Jongbloed wheels. This is what the "fast" endurance teams are using.
    If you run a normal 16 or 17 inch wheel its very likely to clear.
    I race on XXR 530 16x8.25 +0
    If you run a 15 inch wheel less than 9.5" its very unlikely to fit.
    15×7 TRM = does not fit, even with 20mm spacer.
    15×8 TRM = does not fit. Would be close with a 25mm spacer.
    15×8 Team Dynamics = fits with a 15mm spacer, but with VERY little clearance. Would not recommend.
    15×8 Kosei K1 = does not fit even with 20mm spacer.
    15×8.5 Konig = does not fit, even with 20mm spacer. Hits drop center (just barely, but too close to run safely)
    15×10 Basset Steel = Does not fit. Caliper hits mating face of wheel near lug holes.
    This is a to-scale diagram you can print to check different wheels.
    https://racehuggins.com/documents/Hu...tmentSheet.pdf
    Performance:
    The team has competed in two events on this setup so far. In June we ran a 7 hour event at CMP in South Carolina (result: P1) using ST43 pads. In August we ran a 24 hour event (shortened to 19 due to a fog delay) at VIR in Virginia (result: P1) using Ferodo DS1.11 pads.
    Click image for larger version  Name:	CMP_Win.jpg Views:	0 Size:	83.5 KB ID:	10037636
    The $43 dollar "ultralite" rotors were on the car for CMP. For HPDE and mid-pack cars, these are sufficient.
    The $100 "spec 37" rotors were on the car for VIR. They survived 19 hours and will go again at the next event.
    If you want annual brake maintenance on an endurance car the Spec37 + ST43 is the setup.
  • jjc034
    • May 2018
    • 107
    Very nice kit and fantastic research! Thank you for sharing your knowledge and experience.
    I don't think I saw the rotor size in write up unless I missed - how big is rotor with this setup?
    Sent from my SM-G973U using Tapatalk
    • redneckvtek
      • 60
      The rotors are 11.75x1.25 with a 8x7 mounting pattern.
      • NotJesus
        • Mar 2015
        • 169
        Really good deal here folks. I love those brackets and the fact that they support radial mount calipers. Looking at a much stiffer design here compared with the lug-mount style setup that Massive offers.
        • downforce22
          • Aug 2009
          • 3192
          nice setup, only downside is the wheel fitment. We are running an m42 with 15x7 wheels. Currently running the massive lee 'street' kit with corrado 22x 280 mm (11") rotors and the 7812 brake pads (circa 2009 designed by Lee, original thread here https://www.r3vlimited.com/board/for...2mm-bbk-660usd). Currently the 7812 pad shape which is popular with miata guys has the st-43 but it is on backorder. it also only has 12 mm pad thickness which is not a lot.
          i am not sure if 16x8 or 15x10 wheels is going to make sense for me
          • redneckvtek
            • 60
            Agreed, I really limited myself with not being able to fit but one or two wheels.... Thats what happens when you make race car parts first then try to sell them to make them financially viable.
            They won't fit my street car either, so I am working on a V2 kit which will fit 15x7 TRM wheels. The downside is it takes a more expensive caliper (forged superlight narrow) which takes only the 16mm thick pads, and the rotor will need to be narrower. I have two test rotors (11.75x1 and 11.75x.81). The 1" rotor is obviously more mass but is a "rare" size, and the whole point of this kit is easy to get parts. I will make the "v2" with non-floating rotors to reduce cost as well since it will be targeted more towards dual-use cars.
            • hoveringuy
              • Dec 2005
              • 2749
              I'm running the Sparco 15x8 wheels available at the TireRack over a Massive race kit and it clears beautifully.
              • ForcedFirebird
                • Feb 2007
                • 8300
                At first glance, that looked like ERacing 890 overtaking Huggy at Road Atlanta lol. Had to zoom in.
                GLWS.
                john@m20guru.com
                Links:
                • redneckvtek
                  • 60
                  Thats the 11.75x1.25 rotor right? I bet that would clear this kit also. Are you using the FF-1 sparco with a small spacer? I will order a wheel to confirm if so, as that would be awesome to run these on my street car too.
                  • hoveringuy
                    • Dec 2005
                    • 2749
                    Yes. and Yes. The wheels come from the Tire Rack with the 3mm (5mm?) spacer included to bring them to the correct ET, but that's to clear the strut and has little impact on the calipers anyway.
                    • redneckvtek
                      • 60
                      I have some kits left and want to get them off my shelf! Christmas-NewYear special ill sell them for $520 shipped for Hats and Brackets, anywhere in US.
                      Multiple champcar teams using this setup, VIR24 wins on these brakes 2 years running. Plenty of pad left afterwards also!
                      I can get you a discount on the Wilwood stuff as well. I have Calipers, Hardware, and Studs in stock. Rotors are available commercially but I can get those if someone wants a package deal.
                      • redneckvtek
                        • 60
                        Marked the hats and brackets down 20% until the end of the month. $480
                        I’m moving to a new chassis and need to reduce some inventory to make shelf space for new products.
                        I also have stainless brake lines for $100/ set (6 pcs)
