Got mine, just waiting to hook it up!!
e30 Keyless Entry (Sold Out)
Would these work for e28's?
BUY MY WHEELS! BBS E50s!!
http://www.r3vlimited.com/board/showthread.php?t=275407
Originally posted by Lurker27Any man will tell you being blown is better than being stroked.
Originally posted by dunebuggyjay View PostHey guys, can anyone confirm that the green/blue wire is a larger dia wire in the wiring bundle? I'm off to find some splicing connectors.
Thanks.
Jay.
all the other wires were of same gauge.... Also see my pervious post about your wire colors for Lock/Unlock.. Mine were different on my 91 318is.
Transaction Feedback
ok I got this working on my 91 318is I used FLGs wright up.
I had issue before where central locking never worked. my car did come with stock BMW alarm. but alarm wouldn't lock the door and with would only lock/unlock door I had key in. after a lot of googling I fouls that sometimes the actuators are the culprit in causing it not to work. sometimes it's the heaters in the car handles that BMW used so handles wouldn't freeze. problem is the wires powering it are always live and pass through A-pillar plug which catches moisture and cause rust and causes short in central locking. simple way is to cut an splice the to red and black wires going to a pillar from (on car side not on door side) together because one send power and one returns it to make full circuit. an it worked and my central working now works and I installed the kit and it worked great.
tomorrow I will be wiring up lights. I know we can wire them up to head lights. my question is can we get taillights also to flash also? and with hids in headlights isn't that risk of burning out ballast with flashing them.
and other question is with stock alarm when I activated it and opened door without turning alarm off, the alarm would start beeping. and also beeps once for lock twice for unlock anyway of integrating that to this kit.
Sent from my iPhone 4s using Tapatalk
The only problem I've had with this is that the keys are made for righties. You flip open the key with your left hand only to find that the buttons are on the other side of the fob. You privileged right handers don't understand the relentless, unending plight faced by us Left Handed Americans on a daily basis.Last edited by Cliche Guevara; 02-23-2012, 12:43 PM.
Originally posted by Cliche Guevara View PostThe only problem I've had with this is that the keys are made for righties. You flip open the key with your left hand only to find that the buttons are on the other side of the fob. You privileged right handers don't understand the relentless, unending plight faced by us Left Handed Americans on a daily basis.
but this is for you:
