Racing Dynamics m20 e30 headers
  • BeirBrennerE30
    • 2740
    #571
    Originally posted by zaq123
    Did you pay for downpipes too?
    That was included in the initial 1300.
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
    • saucers
      • Apr 2016
      • 280
      #572
      If anyone changed their mind and doesn't want their set anymore, or if there's an unclaimed set Frank :thankyou:
      • zaq123
        • Jul 2016
        • 1568
        #573
        Frank would be the person to answer the downpipe refund question....I would like to know it myself.
        If I understood this correctly, coating was always extra to the initial 1300 though.
        • BeirBrennerE30
          • 2740
          #574
          It was, but I paid the extra $100 and the headers showed up uncoated. I don't mind having to have them coated myself but then refund the $100
          e30sport.net
          • zaq123
            • Jul 2016
            • 1568
            #575
            I would imagine that you’ll be getting it back plus some for downpipes. Frank didn’t say how much he budgeted for downpipes in that 1300, I guess we found out soon enough
            • zaq123
              • Jul 2016
              • 1568
              #576
              Originally posted by 02tradition
              Some minor notes on fitment. The front piece went on perfect no issue :) The back piece required a little massaging of the holes. Flange probably warped slightly under heat of welding, anyways no big deal just reamed out the holes ever so slightly. Also that #5 exhaust stud is still a bear. Shouldn't be too big of a deal. I'll probably shorten the stud slightly and possibly grind a little off the weld off. All other clearances from what I can tell are A OK!
              I don't think the problem with the back bank fitment you had is a warping issue. I have the same issue with mine and the flange is perfectly flat. Most like there was an issue with a jig for drilling those holes. 3 cylinder top bold and 6 cylinder bottom bolt were grabbing, some filing took care of the issue. Some flange welds are definitely need some grinding as the nut bottoms out on the weld instead of the flange. Looks like common for these, judging by Frank's picture of from the previous GB (zoom in on copper nuts)
              • uturn
                • Dec 2010
                • 1008
                #577
                I haven't received my headers yet but being I missed out on the first GB, I'm thankful for Frank doing this second one, all the while knowing the BS he had to put up with the first time.
                Thank you Frank!:up:
                • zaq123
                  • Jul 2016
                  • 1568
                  #578
                  Agreed, there would be no unicorn headers ever again if not for Frank. Thank you sir. Unfortunately it looks like it didn’t go as planned again. 3rd time’s a charm??? Time for GB #3? :)
                  • digger
                    • Nov 2005
                    • 6204
                    #579
                    these are 1-5/8" off the head? mine BTB2/3 are like that and needed to get thin walled nuts and screw the nuts on progressively major PITA on the engine....my custom set will be 1-1/2" off the head stepped to 1-5/8" with no bend nearby to make install easier
                    • uturn
                      • Dec 2010
                      • 1008
                      #580
                      Years ago, I contacted BTB for headers for my m30 swap because Alpina only had half a set left in stock. This was before Supersprint finally decided to fabricate them. BTB said they would not ship to the states.
                      • digger
                        • Nov 2005
                        • 6204
                        #581
                        i got mine through Evolve way back. you'd probably need a freight forwarder otherwise. they dont seem to offer them anymore but they'd be too expensive in any case so it be cheaper to get a custom set...
                        • zaq123
                          • Jul 2016
                          • 1568
                          #582
                          Anyone heard from Frank if we should expect any partial for the lack of downpipes?
                          • SkiFree
                            • Jun 2011
                            • 2766
                            #583
                            Frank, I hope all is well. I have not received my headers yet.
                            ADAMS Autosport
                            • BeirBrennerE30
                              • 2740
                              #584
                              Did we ever get confirmation that these are actual stainless? I have some surface rust inside the collector.
                              e30sport.net
                              • digger
                                • Nov 2005
                                • 6204
                                #585
                                get a magnet, 304 is not magnetic until you work harden it so just try magnet on a straight section of the pipe away from bends, swaged areas
                                the pics from earlier on look like stainless. you can still get light corrosion with 304
