German Engineering Coilovers
  • einstein57
    • Jun 2007
    • 10780
    #106
    If your referring to the AGX inserts they have a pretty large oval. I do have some spares available.
    www.gecoils.com
    • einstein57
      • Jun 2007
      • 10780
      #107
      Lets see some pics
      www.gecoils.com
      • PNWDan
        • Feb 2011
        • 1326
        #108
        I'll post pics of mine for an example for ya Nigel.
        My early model as it sits with the GE setup.
        Front - 5" springs w/sleeves flipped 1/2" of adjustment to go, IE race camber plates, Billy sports.
        Rear standard GE rear coils, no adjusters, Billy Sports.
        Was originally running 6" fronts with sleeves flipped. Will eventually go back to them when I shorten my housings.
        1987 Alpinweiß 325is
        Like the PNW E30 Local Crew Facebook page
        • einstein57
          • Jun 2007
          • 10780
          #109
          :up:
          www.gecoils.com
          • e30experiment
            • May 2013
            • 132
            #110
            does anyone know how much more clearence is gained for offset by removing most of the oem front spring perches?
            • einstein57
              • Jun 2007
              • 10780
              #111
              If your running proper or undersized tires then 0. Typically you can see the tire at or below the factory weld.
              www.gecoils.com
              • poopin04
                • Jul 2010
                • 1396
                #112
                I'm sorry, I might be a bit retarded, but there's no need for welding with these?
                Click here to leave me feedback on our transactions. :p
                • einstein57
                  • Jun 2007
                  • 10780
                  #113
                  None. Unless you want to run shorter inserts.
                  www.gecoils.com
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5272
                    #114
                    would there be any danger of the adjuster/perch sliding off if I were to flip the sleeve upside down? If it came loose, I don't really see anything to stop it.
                    Originally posted by priapism
                    Originally posted by shameson
                    • PNWDan
                      • Feb 2011
                      • 1326
                      #115
                      There are two collars. They get locked in place by tightening them against each other. They won't go anywhere. I've been running mine like that since day one.
                      • einstein57
                        • Jun 2007
                        • 10780
                        #116
                        There is always the possibility of them loosening up and dropping down. I've never recommended that anyone flip the adjuster. Reducing the un-threaded portion of the adjuster will be one of the changes i'll be looking to implement in the next batch. However that is a band-aid. If you want to go low the only way to properly do it is to run shorter inserts. There is just no travel at the height people want to run their cars.
                        www.gecoils.com
                        • MF DOOM
                          • Apr 2012
                          • 944
                          #117
                          Sell just rear springs?
                          • einstein57
                            • Jun 2007
                            • 10780
                            #118
                            I have more front springs then rear so I would not be able to sell rears separately. Added front spring checkout option to my website.
                            Just looked at the packing slip. I ordered 100 front springs. They billed and sent me 111.
                            www.gecoils.com
                            • e30experiment
                              • May 2013
                              • 132
                              #119
                              my bad your right. my car isn't as low as i expected with these in the front.
                              • AE_m20
                                • 548
                                #120
                                just put in my order. Finally some real coils for the e30!!!
                                88 325iS(Cam'ed m20)
                                P2 S60 Daily
                                IG: @ratherbefisting
