24V SWAP Brake Booster Update!!!!
  • up2you
    • Oct 2017
    • 12
    A great fit brake booster, Parts number: 251 612 101 C From VW T3
    only modification need is swap end rod with the big hole from the E30 booster otherwise, it fits right on!
    Although, it is 1CM short to the max length VS the E30 OEM, but it still gives a prefect power boost
    Overall, the fitments is perfect, the fitment is great, the power is decent! No relocation needed!
    I have M54B30 swap with my e30, with this booster, it goes and stops as I wanted!
  • up2you
    • Oct 2017
    • 12
    Fitment overview
    • TobyB
      • 5234
      Hmmm,
      I had a couple of type 3's a long while back-- I'm not finding that part number.
      Are you referring to a Vanagon as a type 3?
      That booster looks like a very good fit.
      t
      • jbontke
        • Mar 2019
        • 448
        Good find! The only complaint I have is replacement parts when you are working with a booster from a car that stopped production in 1973.
        • wazzu70
          • Jan 2005
          • 1143
          Pretty sure he is talking about a T3 Transporter (Vanagon) and not an aircooled.
          -Nick
          M42 on VEMS
          • hoveringuy
            • Dec 2005
            • 2705
            I just measured my booster, which I think is from the 320i, and it's a hair over 9" in diameter. I had the same clearance with my M54.
            • Bored
              • Nov 2018
              • 30
              How does this compare to the X3 booster or E9x booster?
              • Mahalaleel
                • 180
                Right now I'm leaning towards an e83 booster, as it has hookups on the correct side and requires minimal modification to clevis/rod. It does, from what I've seen, require shaving M50 manifold fins.
                Does anybody know of a magic bullet booster/MC combo that fits the bolt pattern, easily mates up with Cleetus, doesn't require remote reservoir, and doesn't require fin shaving? I've been looking at hot rod 8" boosters, but not sure whether they make one that will fit the bolt pattern.
                I was hoping to find an MC/booster combo that requires little or no modification, if possible. So far every thing I've found requires one or two modifications.
                • amcp
                  • 489
                  ATE 944 booster fits your criteria.
                  • Mahalaleel
                    • 180
                    You don't have to shave fins? I thought it fit everything except diameter.
                    • amcp
                      • 489
                      That all depends on motor mounts you use.
                      • Mahalaleel
                        • 180
                        I was planning to use new OEM E28 rubber mounts, as this will be a street car.
