M52B28 Running a little hot
  • e30strokr
    • 211
    yes temp fluctuates like that.... thats why we dont like the stock temp gauge it doenst tell you exactly whats going on.... I believe 220 and up is bad, I have run 210 while having "spirited driving"
    change the coolant mix if possible, run some water wetter
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      Which gauge temp sender are you using? brown top M20? I don't think that's been mentioned.
      Also try to find the part number of whichever thermostat you bought and see which temperature it is. I think 88deg is the correct but there are a few versions.
      My cooling setup is very different, but with an 88degC Tstat + brown top M20 gauge temp sensor I sit somewhere around half while driving, and up to 3/4 idling in traffic before the fan kicks in.
      ECU shows up to ~96 degC in traffic via romraider/INPA/whatever.
      This is with an aluminum Z3M radiator and Spal 16" Pusher fan on an 88deg mercedes switch.
      Originally posted by priapism
      Originally posted by shameson
      • Leonstt
        • Feb 2019
        • 81
        Hi guys,
        I have been searching for this topic for quite sometime now. I havent found a definitive answer.
        I swapped my M40 with M52B28 into a 1990 E30 sedan chassis a while ago and I have been keeping an eye on the coolant temp gauge.
        I didnt trust the factory gauge, so I installed a VDO gauge to monitor more closely. So far, the temp has been hovering around 90-95 deg celcius (194-203F) depending on the traffic condition.
        I did check using a diagnostic tool, my VDO is showing around 5 degrees celcius more than the ECU.
        now, as the title of this post suggest, can anyone tell me what is the normal operating temperature for M52 engines? is there any factory standard?
        thanks
        • Northern
          • 5284
          I see up to 94 degrees through INPA or romraider logger in heavy traffic on a hot day, I think low/mid 90s is fairly normal with a stock 88deg tstat.
          Worth mentioning this is with an aluminum Z3M rad and Spal 16" electric pusher fan.
          • jsta1109
            • Jun 2015
            • 172
            I run the 88c thermostat on an S52, I see 90c - 100c, usually hangs somewhere in the middle. Also, top hose should read hottest which is probably why your gauge is showing slightly higher than the ECU.
            IG: https://www.instagram.com/josh.stacey/
            Flickr: https://www.flickr.com/photos/133952286@N03/
            • Drew325is
              • Oct 2004
              • 520
              On my alloy block M52B28 with 88c thermostat and stock M20 oil cooler I see 93-94oC at highway speeds pretty well regardless of ambient temperature. I'm running the A/C fan only and a very small 7" puller fan and in traffic I will see 96oC...anything higher I get nervous. It's not a daily so sitting in traffic is very rare. On the way to a track day once a small rock hit the oil cooler and I had to bypass it...it showed that the oil cooler makes a big difference in buffering the coolant temps, particular post-track session.
              • Chilezen
                I weld cats
                • Dec 2013
                • 1942
                Why does it seem like I've seen this thread before...
                Aha you've already posted about it. Why are you starting a new one?
                Currently building a badass coffee table
                Random stuff on insta @kevanromero
                • Leonstt
                  • Feb 2019
                  • 81
                  https://www.r3vlimited.com/board/for...67-engine-temp
                  Oh sorry, I posted in several forums and I didn't bother to check. My bad.
                  Anyway, this is the latest development. I put a shroud around the visco fan. It helped a little bit. But on a longer and hot journey, temp started to creep up again. Any suggestions?
                  • Chilezen
                    I weld cats
                    • Dec 2013
                    • 1942
                    My dude, I'm in the same boat, I have a similar thread posted here.
                    What coolant do you have?
                    I'm going to drain my coolant and refill using a vacuum bleeder, to ensure they're aren't any bubbles hiding.
                    If I had the time and money, I would install an oil cooler kit, and wrap the headers with a good quality exhaust wrap.
                    • e30davie
                      • Apr 2016
                      • 1788
                      195F is 90C. Doesnt seem that high?
                      My m20 sits in around 90C according to the VDO temp guage. Are you using the right gauge sender for your oem gauge?
                      • Leonstt
                        • Feb 2019
                        • 81
                        I have Preston red coolant. As for header wtap, I was thinking of installing it but I don't think I can get it done without taking the headers off
                        • Leonstt
                          • Feb 2019
                          • 81
                          I replaced the sender with the OEM BMW one in the original location
                          • 2mAn
                            SeƱior Mod
                            • 21053
                            now they are all merged lol
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • Leonstt
                              • Feb 2019
                              • 81
                              I bought a THINKDIAG scanner just to check what is going on. So here's what I've found. The ECU reads 88 deg Celsius (190F), the VDO is bang on 90 deg Celsius (around 194F), but on the dash shows past half way mark. 2 different readings. Is my dash gauge wrong?
                              • Northern
                                • 5284
                                It's not abnormal for the dash to sit a little high. A difference that small I wouldn't worry about.
