E30 S50 obd1 NO START has FUEL HAS SPARK
  • e30m20TurbO7
    • 1203
    Really stumped on this. I have a 1988 325
    it has a built s50 motor, it has ran perfectly a while ago.
    I was trying to figure out why my other e30 wasn’t starting Soo I had removed the ECU, and the MAF. To use to test on my other car
    I then brought the ecu back and the car would turn on.
    I tried starting it and it was misfiring from an unplugged IAC, the car then I took home and the next day I couldn’t get the car to start
    it would try to start but would just fire here n there but wouldn’t stay running.
    before it wouldn’t run at slll I would hold the throttle down and the car would try to run. But wouldn’t .
    I am stumped because I basically have no clue why the car won’t turn on at all.
    It cranks
    it is getting fuel and is getting spark.
    I’m not sure if the ecm has some sort of bad circuit
    in fairly positive it’s getting fuel to the combustion chamber because the plugs get soaked with fuel when u crank it.
    Soo I’ve tested the relays
    checked the grounds
    front of the engine / ground strap at block
    im going to retest the ecm on my other car to rule that out.
    whether I cooked the ecu.
    Or not.
    im thinking maybe I have a bad tps or iac but I would imagine it would run even if it didn’t have it plugged in
    I’m not sure if they’re any other fuses I should check
    a buddy was saying it could be the OBC
    THE Car is a non 13 button OBC it has the clock. Style.
    As of right now
    there is spark
    and I believe fuel going through the injectors
    feelinf like I’m getting more fuel than I need maybe
    brcsuse when I take the plugs out they’re wet
    when I cranked it this morning after letting it sit over night it fired one little combustion maybe on one cylinder
    I’ve tried different coils
    Snd I’ve tested the resistance in the cps and it has 830 oms
    not sure if that is to much.
    it has a 450lph fuel pump
    whatbwould make the car have fuel and spark but not start
    anything I should check
    Can a ecu make that happen if it has something fried in it
    need some direction
    I’ve checked resistance from engine to chassis and 0 is across the board
    lmk if anyone has any advice
    If I need to check my wiring again lmk I’m stuck
  • e30m20TurbO7
    • 1203
    Has fuel and spark but Onky running off of number 6
    only
    I have spark when I remove a plug and a coil
    but when unplugging each plug. Only the number 6 is firing
    • ForcedFirebird
      • Feb 2007
      • 8300
      What happened when you used the ECU in the other car? If the other car you tested the ECU in had a short, you might have blown the ignition or injector drivers. I have an ECU here that has a dead # 2 ignition driver - I just use it to test if the ECU is bad in other cars.
      john@m20guru.com
      Links:
      • e30m20TurbO7
        • 1203
        Okays ok so I took the ecu from other car
        and basically cars doing the same thing
        it’s getting fuel and spark
        but only spark plug number 6 is firing when the coils are in the head
        what could cause the coils to only be igniting one coil
        I’m loosing my mind I’ll pay someone to help me
        ir if someone is in so cal I will take it to a shop
        I’ve been stuck on this for weeks and don’t know what to try at this point.
        mysterious as f%#k I hate this f$cking car rn spend all this money on a turbo set up
        it ran perfectly then one day decided to just be a pos
        oekase help ANYONE PLEASE
        3102996047
        Name your price
        • moatilliatta
          • 6151
          Try new genuine crank sensor then cam sensor.
          @Zakspeed_US
          • ForcedFirebird
            • Feb 2007
            • 8300
            Dang. I had a car like this once. We could never figure it out, the client gave up, sold the e36m3 for like $2k, turned that and bought an authentic e30m3 for $10k. Two years later, the same VIN shows up on the e36, and it's running, yet only the actual chassis remained.
            I wish you the best, but unfortunately, we can only do so much as a forum based on description and results.
            john@m20guru.com
            Links:
            • e30m20TurbO7
              • 1203
              So tried a known working cps sensor. And I used a known working ECU.
              quite odd it fires on one cylinder .’_#6
              which happens to be closest to fuel line
              that end of the fuel rail is closest to the entry for fuel.
              Things I’ve tried
              different ECM’s
              teo different CPS SENSORS
              Ive tried usiing a different injector on number 6 cylinder
              I’ve checked under the fuel injector / coil pack plastic cover to look for any broken wires or burn out resistors.
              I’ve checked the fuel pump I think it’s priming the fuel pump when starting in accessory positions will do 🫡 iiî
              When I have had the most success of getting it to fire on multiple cylinders
              I had removed each spark plug as they were soaked with fuel and the tips were black.
              Soo when I took them out and wiped them off completely I got it to. Fire when I have the pedal slightly pressed to give it air
              it wanted to start for one crank rotation
              then after that It would only fire one cylinder on every other rotation m.
              • e30m20TurbO7
                • 1203
                I’ve checked the injectors to see if they’re firing
                in my honest opinion it seems like I’m flooding the engine
                snd I’ve checked my. Grounds
                distribution block
                msin engine chassis.
                front of the head ground wire
                The caRS cel is illuminate
                one of my mechanic friends think it’s the OBC
                Thus Car us a factory SETa Sith a clock not a 13bttoon
                He claims there is s BLACK OBC box under the kickppanel which I can’t seem to locate
                he says he’s had Ann e3@ come in shrug sparks n fuel but this OBC wouldn’t allow the engine to idle or run.
                im about to fucken give up on this thing as I’ve been chasing my tail.
                ICV hums
                the card 02 sensor is not plugged in
                the intake temp sensor is plugged in
                the CAM SENSKRis plugged in
                the coolant temp sensor is plugged in
                the. blue sensor is plugged in
                I have pulled the valve cover to check the timing. It appeared to be correct but I ddidnt turn it exactly to TDC
                ive looked at the c101 and checked the wiring
                in thinking there is some sort of grounding issue
                ehrn I crank the car I noticed the coils drop in voltage to around 8-9 volts when cranking
                the main relay I’ve checked voltage and it’s right under 12 volts after cranking a lot
                is it possible that the plugs could go bad from to much fuek.
                I noticed the only time I’ve gotten it to run since it stopped running is ehh I’ve cleaned the plugs.
                in thinking maybe I have a wire grounding out on another
                or something electrical I’d causing this issue .
                will pay someone if I can get it running
                or if they have an extra obd1 wiring harness or if someone does custom wiring harnesses not adapters
                i would be interested in buying one as I think it has to do with my harness more than any thing I’ve done countless hours of diagnostic
                but I’m about To give up do any input would help
                can A ground only ground half or more than half the coils
                very intermittent issues
                .Can a bad maf or IAC cause any of this ?
                or bad gass
                Or the plugs taking a shit seems like the plugs aren’t grounding out
                • moatilliatta
                  • 6151
                  What’s is your fuel pressure?
                  @Zakspeed_US
                  • e30m20TurbO7
                    • 1203
                    I’ll check fuel pressure haven’t checked that yet
                    • e30m20TurbO7
                      • 1203
                      Just confirmed. Fuel coming out of injectors
                      • moatilliatta
                        • 6151
                        Id check actual fuel pressure.
                        What faults are you getting?
                        @Zakspeed_US
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Check the crank hub. Recently the spec e30 guys have been having issues with the reluctor wheel slipping on the dampener. There's only rubber attaching the toothed wheel to crank pulley, and that's where the ECU gets timing from.
                          john@m20guru.com
                          Links:
                          • e30m20TurbO7
                            • 1203
                            That’s honestly what it seams like because I’ve made that mistake before clocking it wrong Maybe the balancer failed
                            • moatilliatta
                              • 6151
                              It’s pinned and only orientates one way. NV engine have different timed missing tooth compared to the pin and isn’t interchangeable for reference.
                              @Zakspeed_US
