Can you stroke a M52TUB28?
  • DomJK
    • Mar 2024
    • 1
    I've got a 2000 528i with double vanos (M52TUB28) and I was wondering what parts would I be able to use if I wanted to build or buy a stroker kit as my motor is getting weak and needs a rebuild plus I'm planning on either putting a supercharger back on the car or putting a turbo on it
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5602
    Yeah, you can use rotating assemblies from M5x/S5x.
    You should be able to search and find what you need
    • digger
      • Nov 2005
      • 6196
      s52b32 or m54b30 89.6mm crank or even the s50b30US 85.6mm crank are all longer stroke than the 84mm in your engine.
      the rods will be the same 135mm length and pretty much interchangeable
      pistons are different bore between m54 84mm and S50 86mm / S52 86.4mm but if getting machined then not an issue and better to increase the bore to get fresh bores and a few extra cc. not sure if the M54 engine deck height and the m5x/s5x deck height are the same i recall 211 and 210mm respectively. i would suggest s52 pistons may be the best for that block in which case with some boring and honing the s52 full rotating assembly should fit perfect.
      im sure others will chime in.
      • Northern
        I like cupcakes & sh!tboxes
        • 5283
        Unless there's specifically an issue with your bearings/rings, or you have the engine apart already to upgrade pistons/rods for FI, I'd just send it on the stock bottom end.
        The return per dollar to stroke it with stock parts on an FI engine isn't worth it unless you are simultaneously doing something to the bottom end to allow it to take more boost or abuse.
        Originally posted by priapism
        Originally posted by shameson
        • Mike36
          • 1079
          Have you rebuilt your vanos yet? Also, what supercharger did you have on it before?
          • TobyB
            • 5290
            Isn't the M52TU an aluminum block/iron cylinder core like the M54?
            In which case, the 'liners' are only a couple mm thick, so boring for displacement doesn't net you much...
            +1 for not bothering for forced induction- you'll do better to just up the boost a little.
            t
            • digger
              • Nov 2005
              • 6196
              isnt it only europe with alloy m52?
              • Northern
                • 5283
                M52TU is Aluminum worldwide. Not sure if they're steel liner or Alusil/electroplated liner.
                I've seen people resleeve the steel liner M52 non-TU at stock bore, no idea if there's room to overbore in the TU, but I really don't think it's worth looking into for the cost/benefit.
