Wiring a C101 Connector: Geting Pins, Crimpers and a Cheap Pin Removal Tool!
  • R3VM3UP
    • Jan 2017
    • 170
    #61
    Bumping this thread to add another method of pin extraction. I needed to remove some pins today but couldn't find a suitable tool, so I had to get creative.
    Basically what I figured out is you can take a piece of plastic from some packaging and cut a rectangle, then wrap it around some wire approximately the same diameter as the c101 pins to get it in a roll that is about the right size. You can then insert it around a pin to release the tabs. It took a bit of trimming to get it the right size since you want the roll to be the exact circumfrence of the pin with no overlap ideally. The plastic I used was some stiff packaging from a tube of loctite.
    • KIRIEIW
      • Dec 2012
      • 3385
      #62
      Heres the tools I used to re pin mine. All the part numbers for the pins and stuff listed on post 1 are what you'll need.
      IMG_7941 by Kevin O'Brien, on Flickr
      IMG_7946 by Kevin O'Brien, on Flickr
      IMG_7948 by Kevin O'Brien, on Flickr
      Pin removal tool.
      IMG_7953 by Kevin O'Brien, on Flickr
      Finished.
      IMG_7956 by Kevin O'Brien, on Flickr
      1992 e34 Touring- S50 Swap
      1992 325i-S50 Swap (SOLD)
      1991
      • burkey001
        • Feb 2011
        • 608
        #63
        bump...
        any good ideas how to get the female pins out of the chassis side of the C101?
        cant see how they come out... sad.. or if they can come out
        88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
        90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
          • 34839
          #64
          You need the pin removal tool. either buy or make one. IIRC it's the same tool.
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #65
            Would someone mind removing the apostrophe from the title?
            • ZekeTheSneak
              • 1562
              #66
              You need to unlock the twist lock pin holder. I used a pick tool. Same thing works for the diag connector. Then you need to make a round pin removal tool. Old antennas or those extendy magnets work great. Just cut it apart.
              • projectJTv4
                • Sep 2019
                • 171
                #67
                Originally posted by nando
                you can get them on mouser.com. I usually buy in a reel of 500.. lol. Haven't used any in a long time though.
                Do you happen to remember the mouser part number?
                Edit: It's been almost 5 years since your original post, but you're still active here :)
                • Northern
                  • 5164
                  #68
                  For C101/X20 - stolen from bmwman91 's thread (slightly edited, original here ) :
                  2.5mm round male terminals:
                  TE 929963-1 (for 0.5-1.0mm^2 wires)
                  TE 929964-1 (for 1.0-2.5mm^2 wires)
                  2.5mm round female terminals:
                  TE 929970-1 (for 0.5-1.0mm^2 wires)
                  TE 929971-1 (for 1.0-2.5mm^2 wires)
                  More pin PNs in his post.
                  Originally posted by priapism
                  Originally posted by shameson
