Round 2! Fight!
  • jahnaboi
    • Oct 2006
    • 1742
    Stripped the motor down to assure everything is on correctly and got to clean the motor and its components as well as the transmission.
    koole30 does paint and bodywork for anyone who cares and needs services. He will be painting my car (hopefully for my efforts ) and I'll show case the great quality of his skills.
    I started assembling the motor hopefully to have it in by this weekend.
    -Jasper
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • bimmer_E30
      • 5001
      Subscribed :)
      Originally posted by e30e
      • deutschman
        • May 2008
        • 5958
        very nice clean work so fare. this will be a nice swap.
        • 5KWattson
          • Apr 2009
          • 809
          LOOKS AWESOME. i only wish i had the money for a s52 when i bought my m50, but in time.
          "God created turbo lag to give V8's a chance" Taylor D.
          • samiam3356
            • Jul 2009
            • 1901
            What do you use to clean the block, acceories, and head? How ever or whatever you use works really well. Both of your swaps look very clean. I'm in the process of cleaning my block and accessories now but decided to have the head rebuilt.
            Originally posted by Roysneon
            $5 shipped?
            Originally posted by MarkD
            You are a strange dude, I'n not answering any more posts from you.
            • 5KWattson
              • Apr 2009
              • 809
              i didnt have the luxury of chemicals to clean my motor before install, but i did have a 3100psi pressure washer which did very nicely
              • jahnaboi
                • Oct 2006
                • 1742
                A pressure washer. But used correctly.
                I bought this because I like things clean so it was a must have.
                Yup. That's what I used on both my swaps.
                I went to the junkyard to grab couple more things. I got the brake booster and new oil pan. Gotta clean them up. Still need to get the transmission brace, and couple of wiring stuff. Looking good so far!
                -Jasper
                • 5KWattson
                  • Apr 2009
                  • 809
                  hella! i did my whole engine bay under the car, the e34 oil pan and the m50(prior to removal of e36 pan) turned out great...sad part is a month after the swap my oil filter adapter gasket stared leaking so now the oil pan, rack, steering, trans, under body are all coated in 10w-40 again...tragic
                  • markseven
                    • Sep 2006
                    • 5327
                    Nice work so far!
                    I Timothy 2:1-2
                    • jahnaboi
                      • Oct 2006
                      • 1742
                      Haven't updated in a while because not much work was done due to this weather. But I'm full steam ahead with minimal parts need to have a complete finished car. I will be slapping the motor and wiring harness together and putting it in tonight. Still missing the manual transmission brace for a late model e30. If anyone local has one I could have or possibly buy for cheap please let me know. No late model 5 speed e30s in the junkyards so let me know! On to the pictures.
                      E34 Oil Pan on.
                      NGK Platinum Spark plugs and coil bolted down
                      Customized e30 temp sensor. Shaved down and threaded to fit into coolant feed hole in s52 head.
                      E32 Double stack booster + Master Cylinder + E34 M50 Throttle Cable Installed. Still need to buy brake line hoses and nipples to make the remote reservoir and possibly the 2002 reservoir.
                      That's all for right now. Will update later tonight.
                      -Jasper
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        Nice! Stoked to see how this turns out, looks to be going very smoothly so far.
                        • jahnaboi
                          • Oct 2006
                          • 1742
                          Well, customized the obd1 wiring harness bracket, put the flywheel/clutch/pp on, put the transmission/fork/slave cylinder on.
                          Things that need to be done before I throw the motor in the engine bay:
                          - Weld obd2 manifolds for obd1 application
                          - Connect wiring harness + vacuum lines
                          - Find a e36 power steering reservoir bracket
                          Still quite a few stuff to get (ahem koole30) but she should be up and running very soon.
                          -Jasper
                          • e30polak
                            • 6136
                            Pft...I thought you'd be done already Jasper, quit laggin it! :roll:
                            LOL jk. Good work mang, keep it up!
                            INSTAGRAM: @UNDR8D_EMPIRE
                            • Jean
                              • 18228
                              You work fast!
                              • bimmer_E30
                                • 5001
                                just ship it to me, god i want a amotor swap badly.
                                good work!
