What to expect from HFM, injectors, chip?
  • hoveringuy
    • Dec 2005
    • 2750
    My M54 originally came with a 3 1/2" MAF and a larger throttle body than the OBD1 motors.
    Even with OBD1 components, I'm making more HP than a stock M54.
    I've done a ton of datalogging on it and found that the MAF isn't getting close to saturation (plenty of signal headroom left) but I am starting to draw a slight vacuum in the manifold at higher rpms. That is a result of the entire intake tract, including throttle body, MAF and air filter.
    I suspect that the combination of the larger, stock throttle body and 3 1/2 MAF may yield me a few ponies.
    Why would they give the 3.0 M54 a larger TB and MAF than the stock S50? Must be a reason...
    • triggrhaapi
      • Feb 2007
      • 350
      They probably thought it was better so they used it. M54s are Drive By Wire, so it might also have something to do with that.
      1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
      • russiane30
        • Dec 2008
        • 46
        love it
        • matt
          • 3732
          Originally posted by triggrhaapi
          Really all that the MAF and injector combo does is allow a richer mixture in the mid to high range that allows for a mildly more aggressive ignition map.
          There isn't really a big gain to be made there, because the cam isn't aggressive enough to draw more air really, and the fuel isn't high enough octane in this country to make a more aggressive ignition map feasible.
          With higher octane fuel, or ionic sensing ignition, there would still be significant gains to be made.
          No, what the MAF does is give tuners something else to charge you for. Maybe it flows a little more air, it probably doesn't hurt.
          You can get whatever mixture you want with whatever MAF (and injectors, as long as they are big enough) you want.
          • hoveringuy
            • Dec 2005
            • 2750
            I am also looking at an electric power steering pump. It will give me another 5+ hp across the entire power band.
            • sharky
              • Jan 2005
              • 2672
              Originally posted by russiane30
              love it
              Cut down the elbox 3 inches, clock your maf connector to the 2 o clock position and run the 3 in cutoff in front of the MAF to the filter. This will result in better flow and allow the MAF to meter correctly
              • triggrhaapi
                • Feb 2007
                • 350
                Lazy tuning maybe? Maybe they did it because a faster throttle response makes people think the car is faster? I never bought it myself, I'm still running the stock MAF and injectors. I don't need more fuel until I can get a lot more air. For that I need cams.
                • Lof8
                  • Oct 2006
                  • 2827
                  Anyone with experience with the hfm/injectors/chip combo wanna throw out a butt-dyno guesstimate?
                  S50'd
                  Originally posted by TDE30
                  What is this faggy shit I have happened upon?
                  I can always live in a M3. Can't M3 a house.
                  • flyboyx
                    • 8371
                    did you reset your dme with a peak reset tool or equivalant? i don't care how many injectors or harnesses you replace, if you don't reset the code in your dme, it will never go away. i think it is very common to see injector 1 failure with a swap. i had it too. in everything i read above, i didn't see anything about you mentioning resetting your codes.
                    Gigitty Gigitty!!!!
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      Is this meant for 87e30's thread?
                      '89 Alpine S52 with goodies
                      • Lof8
                        • Oct 2006
                        • 2827
                        yeah, wrong thread?
                        S50'd
                        • matt
                          • 3732
                          I would say you'll see 10-15hp. Maybe a few more than you'd see from the chip alone.
                          It's a nice change for sure.
                          • Lof8
                            • Oct 2006
                            • 2827
                            hmm, not quite worth the ~$500 imo. I'll rock it as is for a while longer and work on cleaning up the engine bay for my next project.
                            S50'd
                            • MatRacer
                              • 562
                              Originally posted by e30polak
                              Especially since you can just get your s50 cams reground to Schrick specs for $250-300 and come out with a nice increase in performance.
                              Who does that and how they do it?
                              I bought 6 24# injector from Fuel injector connection on Ebay. it was 129$ for 6. And the HFM was 130$ from a BF.c member. 260 + shipping isn't that bab for 10-15 hp!
                              E30 now S52
                              2008 Suburban LTZ (Family and TT hauler)
                              325xiT (Sold)
                              • Lof8
                                • Oct 2006
                                • 2827
                                yeah, you still need the $250 chip
                                S50'd
